Revision as of 20:54, 11 July 2008 by LubinKerhuel (talk | contribs)
After a quick description of the angle estimation using accelerometers or gyro, this document describe the electronics board and explain how logging data throught the UART port of the PC. Then, the document presents the different estimation methods that fuse data from gyros and accelerometers to retrieve the atitude of the IMU system:
  • Complementary filter
Simulink simulation of theses two methods, relying on real data previously logged, provide an easy way to tune each method, and to compare their efficiency. Once tuned, one method is implemented in the embedded PIC or dsPIC microcontroller in no time with the one push button method: the rapid prototyping tool described on this website (dsPIC blockset for Simulink).
<Tex>\hat \Phi(t) = \int_ t_0^t{p(t) dt} + \Phi(t_0)</Tex>
However, the first weakness of the angle estimated from accelerometers is its sensbility to the acceleration of the system. In others words, the estimated angle is biased whenever the system accelerates. The second weakness is the noisy result due to the accelerometers sensors.
Angle estimation from either a rate gyro or an accelerometers only do not provide good results. The characteristics of these two types of sensors are complementary:
The dsPIC:used (dsPIC 30f4012) is equipped with a 10Mhz quartz. This quartz frequency allows using the UART at 115200bps which is the max baud rate available on most personal computers (Serial port's limitation).
  • model time-step is 1ms
IMU_dsPIC_30f4012_TestElectronics Simulink model: Once this model is compiled, the dsPIC (30f4012) transmit the values from the X, Y and Z axis of the accelerometer, and the Y and X axis of the rate gyro. Data are sent to Matlab (or labview) through the UART at 115200bps with the Tx Output Multiplexed for Matlab-Labview block. All data can not be send ; there will be missing data thus this model is usefull to check every component is working only.
The model IMU_LogData is compiled and the generated .hex file is loaded into the dsPIC (using the bootloader tinybld). The model samples the data at 1kHz, corresponding to the time-step of 1ms. During 1ms, the UART can send 11,52 Bytes when configured at 115200 bps (taking into account the start and stop bits). We log 5 int16 data that correspond to 10 bytes. The multiplexing protocol of the Tx Output Multiplexed for Matlab-Labview block.]] adds one byte for each variable sent. Thus, the model send 15 bytes at each time step. Because the model sends more than 11 data by time-step, some data will be lost. The Intelligent Spreading option will spread the lost over all data allowing to view all data on the graph (If not checked, the two last data may never be sent).
Because of the lost of some data, it is OK for plotting data and allows checking than all components are working. It is Not OK to use theses data as input data in a Simulink simulation! (You may however interpolate the data…)
The dsPIC is connected to the PC COM port (using an equivalent to Max232 component for level translation) and data are logged using the graphical user interface. The following lines are typed at the maltab prompt to save data into a .mat file :
 >> [R T] = padr(Rn,1,t_Rn);                                         % remove NaN values
 >> datas = [T R]';
 >> save mydatafile datas;
The file obtained here can be used in simulink, however one must keep in mind than missing data on columns [2 3 4 5] are stuffed with their previous non missing value. Missing data on column 1 suppressed the time step. In other word, data is corrupted and should not be used in simulation. If we decided to log 3 datas only (2 accelerometers and 1 gyro), all data would have been received (9 bytes per time step). The resulting file would have been usefull for a simulink simulation. However, the method described below allow to log the 5 datas without missing data!
IMU_dsPIC_30f4012_LogData_Raw Simulink model: Once this model is compiled, the dsPIC (30f4012) transmit the values from the mems sensors. Data are sent to Matlab (or labview) through the UART at 115200bps with the Tx Output block. All data are sent making the logged data complete and useful for feed a simulink simulation.
The UART at 115200 can transmit only 11,52 data in a 1ms time-step. Thus, the simulink model implemented on the dsPIC must transmit less or equal 11 datas to be sure that there will be no data lost.
5 data with 12 significant bits must be transmitted. The solution used code each data into 2 data bytes. One byte with the value 55 sent first is sent before the 10 frame bytes of the model to provide a synchronization reference. This byte may also be used to check that no data were lost (checking that 10 bytes are present between two 55 values).
No use multiplexing ==> use Raw data on Rs232gui Data are sent when the variable60 gets a no null value… Matlab Script description
Simulation based on real data
Angle estimation fusing rate gyro data with accelerometer data: A complementary filter combines the two estimation. High frequency part of the angle estimated from the rate gyro is added to the low frequency part of the angle estimated with the accelerometer. Thus, the low drift of the estimated angle from the gyro is filtered and only high frequency estimated angle from the gyro is used. The low frequency part of the angle estimated rely on the angle estimated using the accelerometer. The high frequency of the angle is estimated with the gyro which provide a fast and accurate information but which cannot be integrated due to the accumulation of the bias error.
The model IMU_Simu_RealData uses the logged data contained in the file AxelX_GyroY_AxelZ3.mat. These data are used to design a simple complementary filter and simulate it. Because we are using real data, the input of the simulation has precisely the right properties (noise, bias...). The filter can be design and simulated with data that are close to reality. In this model, datas are converted back into their former fixed point representation data type. In other word, their binary data is not modified, but the scaling is modified. After the first conversion block, they are equivalent to the data of the IMU_sensors block of the previous model. Data are converted again into double or single to simplify the design at this step. The upper part of the model estimates the Y axis angle computing the atan of the X and Z accelerometers values. Because we use the Atan function, the two accelerometer axis do not need to be scaled. The only constraint is that the X and Z acceleration share the same scaling. The lower part of the model estimates the Y axis angle integrating the Y rate gyro. The dynamic of the gyro (low pass filter) is compensated for. The rate gyro is also high pass filtered to remove most of the DC part. The complementary filter, two first order filter (high pass and low pass) with cut off frequency at 0,08Hz. The final estimation of the angle is the addition of the resulting values from theses two filters. The result is presented in pink on the lower part of the following figure.
Download the three models described above here with sample of sensor's data. The aim of this complementary filter is to provide a method to implement a model on the dsPIC that has been previously improved thanks to the simulation capabilities of simulink. Simulation uses real data logged with the dsPIC peripheral (same electronic circuit, noise etc...) In a first step, the real data are logged by the first model IMU_LogData. The complementary filter is simulated using the real data in the IMU_simu_RealData. The resulting model is then implemented into the dsPIC in the IMU_ComplementaryFilter model.
The estimated angle using accelerometers (blue curve) is quite noisy. However, it steady value is correct. The estimated angle relying on the integration of the gyro is clean but drift (red curve). Note that the dsPIC has just been switch on and the High pass filter of the pseudo integrator of the gyro has not yet removed the remaining DC bias of the gyro. The DC bias of the Gyro has probably change due to non constant temperature in my house. (I do not have a clim in my tiny room which is in a roof in Marseille! ). Thus, the gyro integrated angle is slowing drifting away from its real value. The green curves that use both data is clean and drift free. Its dynamics is as fast as the gyro dynamic. Note that at the beginning, the High pass filter (with a higher bandwidth than the gyro pseudo-integrator high pass filter) has not yet removed the gyro bias. However, at the end of the animation (11 secondes long: from 3, 5 to 14, 5), both curves (blue and green) are merging as in the simulation.
The IMU_ComplementaryFilter simulink model is a 'copy-past' mixture made of the IMU_LogData 'data management' part with the IMU_simu_RealData model tuned and optimize filter. This model implements the complementary filter on the dsPIC and sends the result to matlab. It will have the same behavious of the simulated filter.
Remarks about the complementary filter
The integration of the gyro should be done after the high-pass filter of the complementary filter. This filter placed before the integration would avoid getting high value in the integration internal computation. High value with floating point data mean that the calculation loses its precision. The high-pass filter of the complementary filter has been placed at the end for reason of simplicity and to compare easily the estimation of the angle with the three methods ( integrating gyro, using accelerometer, or by combining both).
All calculation are done in double data type or single data type. Theses float data slow down the calculation and use a large amount of memory. It is quite powerful with the help of simulink to build a fixed point complementary filter. Thus, next step is to go back to the simulation model and to design a fixed point complementary filter! (Using the matlab fixed point toolbox)
Alpha Beta Filter
coming soon
On-going projects
