Release Notes
Revision as of 21:03, 15 June 2008 by LubinKerhuel (talk | contribs)
    • Find and corrected one bug in the "Output Compare"
Block Know bug : before compiling schematic for dsPIC 24f, you must remove the line 56 of Generic.h file which is in "C:\Program Files\Microchip\MPLAB C30\support\h\peripheral_24F" The line : "typedef enum _BOOL { FALSE = 0, TRUE } BOOL;" does not compile !
Know BUG : Output Compare PWM generation does not work when Power Save mode is activated on 30f4013 and probably on others chips! Output Compare is working otherwise Know bug : before compiling schematic for dsPIC 24f, you must remove the line 56 of Generic.h file which is in "C:\Program Files\Microchip\MPLAB C30\support\h\peripheral_24F" The line : "typedef enum _BOOL { FALSE = 0, TRUE } BOOL;" does not compile !
Thanks to Evidence Srl for providing a Flex Board for Microchip dsPIC based on 33FJ256MC710 allowing to test the toolbox with this chip. Know bug : before compiling schematic for dsPIC 24f, you must remove the line 56 of Generic.h file which is in "C:\Program Files\Microchip\MPLAB C30\support\h\peripheral_24F" The line : "typedef enum _BOOL { FALSE = 0, TRUE } BOOL;" does not compile !
    • Works with the last version of the Microchip dsPIC and PIC24 C compiler (v3.10) and with the PIC32 compiler (v1.02)
!! Updating your compiler is necessary !! (download from the microchip website)
  • Next Release : V0.98d
