Lets:
- <Tex>\Theta= \arctan \left( \frac{a_z}{a_x} \right)</Tex>
- <Tex>\Phi = \arctan \left( \frac{a_z}{a_y} \right)</Tex>
Log real data
Simulation based on real data
Remarks
Futur work
