Lets:
- <Tex>\Theta= atan \left( \frac{a_z}{a_x} \right)</Tex>
 - <Tex>\Phi = atan \left( \frac{a_z}{a_y} \right)</Tex>
File:IMU With dsPIC.zip the three models described abore here with sample of sensor's data.
Log real data
The model sample rate is 1Khz, corresponding to a time-step of 1ms. During 1ms, the UART can send 11 Bytes when configured at 115200 bps (including start and stop bits).We log 3 X (int16) data (X and Z acceleration ; and Y raw gyro). Adding one protocol byte for each variable sent, the model send 9 bytes at each time step. Because the model send less that 11 data by time-step, all data will be sent and logged by the PC. Note that if the model send more that 11 bytes, some data would be lost (it is OK for visual checking but not for use as input data into in a simulation).
Simulation based on real data
Data logged in real time from the complementary filter implemented on the dsPIC (30f4012 running at 10MHz). X axis : time in second. Y axis : angle multiplied by 100 (see model)
  Remarks
Futur work
