Lets:
  • <Tex>\Theta= atan \left( \frac{a_z}{a_x} \right)</Tex>
  • <Tex>\Phi = atan \left( \frac{a_z}{a_y} \right)</Tex>
Log real data
>> [R T] = padr(Rn,1,t_Rn);
>> AxelX_GyroY_AxelZ = [T R]';
>> AxelX_GyroY_AxelZ(1,:) = [0:33332]*1e-3;
>> save AxelX_GyroY_AxelZ3 AxelX_GyroY_AxelZ;
Simulation based on real data
Remarks
Futur work
