Revision as of 00:40, 31 December 2010 by LubinKerhuel (talk | contribs) (Created page with "=Description= The objective of this example is to demonstrate how to use a Pulse Width Modulated (PWM) signal to transmit data between two microcontrollers. One dsPIC (30f3012) ...")
Description
The objective of this example is to demonstrate how to use a Pulse Width Modulated (PWM) signal to transmit data between two microcontrollers. One dsPIC (30f3012) send to another dsPIC (also 30f4012) values through one PWM signal (i.e. one wire). Both dsPIC are programmed using blocks from the dsPIC blockset for simulink available on this website. This example was added in the blockset version 3.4.
Next to come...
