DsPIC Block/Output Compare
Jump to: navigation, search
Block Output Compare
Outline
Output Compare Dialog
  • Time Up and Period
  • Time Down and Period
  • Time Up and Time Down
With
Clarifying note regarding OCkmax: OCkmax is relevant to the internal chip frequency (typically depending on quartz and PLL used). the dsPIC blockset evaluate this variable in the MATLAB workspace. Type "who" at matlab prompt to list all variable. Get the variable value typing its name "OC1max" (case sensitive). There are two OC blocks : The OC hardware block creates one variable OCmax. The OC block creates multiple variables OC(x)max with x, corresponding to each channel (1, 2 3 or 4)
Interrupt Priority
Output Channels
Channels Input Type
Max/Channels
Related block & Examples
Related block:
Examples:
