Measuring the Back EMF
- The PWM duty cycle
The design of a controller requires a model. A second simulink model programs the microcontroller to test the dynamic response of the motor. The Back EMF is there always sampled at the instant 11970 (we takes some safety margin). The PWM duty cycle is now a chirp signal (sinus with increasing frequency) that makes the motor to accelerate and to slow down at increasing frequency. We supposed that the Back-EMF is an image of the moto speed rate. Thus, the motor model is identified using the matlab ident graphical user interface.
<Tex>G_{motor}(p) = \frac{-24.62}{(p+78.65)(s+9.78)}</Tex>
Controller design
The controller is designed keeping with theses two constraintes :
I decided to use an augmented state space model. A state space model has the advantage over a PID or PI only system to filter the output thanks to the internal model. The augmented stats is the integral of the error, providing thus a controller with no steady state error.
We use the matlab new command lqi (available from Matlab 2008b) to compute the matrix gain K. The observer gain L is computed so as to get an observer pole as slow as the slowest pole of the close loop control system. Such a low gain allow to filter efficiently noise comming from the PWM measurement.
We get results for L and K : L = [-0.0593 0.826] and K = [0.5 1.2 1363.9]. With this design, the new motor time constant is The time constant of the motor <Tex>\tau_{CloseLoop} =70ms </Tex>. Thus a 30% improvement. This improvement is not very huge. We are limited here by the necessity to have a low noise command signal. However, the close loop will counteract for the battery decreasing power.
Results
SensorLess_Speed_Controller_ForPicooz.zip
The zip file contains all matlab files as is.
