Measuring the Back EMF
- The PWM duty cycle
The design of a controller requires a model. A second simulink model programs the microcontroller to test the dynamic response of the motor. The Back EMF is there always sampled at the instant 11970 (we takes some safety margin). The PWM duty cycle is now a chirp signal (sinus with increasing frequency) that makes the motor to accelerate and to slow down at increasing frequency. The motor model is identified using the matlab ident graphical user interface.
