I did not build any embedded electronic system for the PICOOZ. Thus, this is a demo example build on the Explorer 16 board, using the PIC32MX460F512L gracefully provided by Microchip. Converting the code for others dsPIC (30f, 33F, 24h) is quite straight using the Simulink blockset.
