The The micro-Inertial Measurement Unit (IMU) measures the absolute angle (or attitude). It is made of
IMU sensors : 1 accelerometer MMA7260 from freescale (3 axis) coupled with 2 gyrometers ADIS16080 from analog device (1 axis each)
Fusing speed rate with acceleration ?
Angle estimation using accelerometer data only : Accelerometer sense the gravity acceleration added with the acceleration of the sensor itself. Decomposing the gravity vector on the accelerometer axis is unique except for the yaw rotation axis. The resolution of the roll and the resolution of the pitch angle is done using the atan function. Note that calibration of the accelerometer is not necessary with the calculation. We must just have the same scale for the three axis measured.
roll = atan(z/x) with x the roll rotation axis, and z the yaw rotation axis
pitch = atan(z/y) with y the pitch rotation axis, and z the yaw rotation axis
This IMU use three sensor : One Three axial accelerometer and two one axis rate gyro. The accelerometer is powered by the 2.5V analog refference of the 'Y axis' rate gyro.
Log real data
IMU_LogData Simulink model : Once this model is compiled, the PIC (30f3012) transmit the values from the X and Y axis of the accelerometer, and the Y axis of the rate gyro. Data are sent directly to Matlab (or labview) through the UART at 115200bps thanks to the Tx_Labview_Matlab bloc.
Simulation based on real data
Top curves : The X (yellow) and Z (cyan) accelerometers raw data with the Y axis rate gyro (pink). The y scale is the raw numerical value as read from the Gyro-SPI bus. The x scale is time (simulation duration is 33,32s). The three bottom curves are the simulated estimation of the angle (Y axis) using three different methods. The yellow curve is the estimated angle from the X and Z accelerometers, sensing the gravity. The cyan curve is the estimated angle, integrated from the Y rate gyro. The pink curve is the estimated angle estimated with the complementary filter that fusion the relevant informations from both the Y rate gyro and the X-Z accelerometer.
Remarks
Futur work :
