The RC model airplane
Caracteristics :
- 1m25 wingspan
- 400g weight
- 2 actuated surfaces
Embedded System
Classical RC Material
- Two servo motor (HPX )
Calculator
Sensors
boite maxim DALLAS : 9.35g
total : 85.71g
Recording In Flight Data
Data Recorder
SST
Telemetry
