- 1 The RC model airplane
- 2 Embedded System
- 3 Rate gyro and Accelerometers data in flight
- 4 Airplane dynamics identification
- 5 Angular rate control loop
- 6 The RC model airplane
- 7 Embedded System
- 8 Rate gyro and Accelerometers raw data in flight
- 9 Airplane dynamics identification
- 10 Embedded controller
Caracteristics :
- 1m25 wingspan
- 400g weight
- 2 actuated surfaces
Embedded System
Classical RC Material
- Two servo motor (HPX )
Calculator
Sensors
From both the rate gyro and the accelerometers, it is possible to compute the attitude of the plane. For more details on the calculation details, see the page dedicated to the Inertial Measurement Unit (IMU).
Recording In Flight Data
Data Recorder
SST
Telemetry
