Explorer 16 Board
Revision as of 22:45, 13 October 2010 by LubinKerhuel (talk | contribs)
  • One led (Port A7) :
Set UP
Simulink
PIC
Master block configuration
Open the Master block.
Set up PIC peripheral
Digital Input Configuration
Digital Output Configuration
ADC Configuration
UART
UART Peripheral Configuration
Functions
Blinking Leds
Filtering
>>c2d(tf([6],[1 6]),.005,'tustin');  %(need the Control System Toolbox)
[Report] [Report]
[Hex file] [Hex file]
Log and Plot Data
Pic side
Computer side
