DsPIC Block/SPI Input Output
< DsPIC Block
Revision as of 18:30, 3 May 2015 by LubinKerhuel (talk | contribs) (LubinKerhuel moved page Block/SPI Input Output to DsPIC Block/SPI Input Output: Block is a special page, creates many issues)
Block SPI Input/Output
SPI Input Output Dialog
Example of SPI block reading data from an rate-gyro (ADIS16100). Chip Select of the rate gyro is connected to the B4 dsPIC pin which is activated just before execution of the SPI block. Note the Ordering connection to force block ordering.
n° SPI
SPI used
SPI Input
SPI Output
Special SPI
Allow to disable SPI pin function and to use theses pin as digital input/output. The choices are :
  • Always Enable
  • Disable After block execution
  • Re-Enable before block execution
  • Re-Enable Execute and disable
Data Length
