DsPIC Block/PWM Motor Output
< DsPIC Block
Revision as of 18:30, 3 May 2015 by LubinKerhuel (Talk | contribs) (LubinKerhuel moved page Block/PWM Motor Output to DsPIC Block/PWM Motor Output: Block is a special page, creates many issues)
Jump to: navigation, search
Block PWM Motor Output
Main Dialog Box Parameters
PWM Motor Output main Dialog
General Input Enable
Input Periode
Output Channel
Periode
With
  • Tset = the requested time in second (should be inferior to Periode)
  • Periode = The literal value (in second) you defined in the Periode dialog box
  • PWMmax = a constant automatically evaluated in the matlab workspace
for example, a 1ms is coded with (Periode is set to 20ms : [math]20*10^{-3}[/math]):
ValMax Periode Calcule
Centered
Edge-Aligned PWM vs Center-Aligned PWM. Center-Aligned PWM multiply by two the max Period and Duty Cycle achievable
Gives information :
Dead Time TAB
PWM Motor Output Dead Time Dialog. some dsPIC has only one Dead Time Prescaler. This Dialog may be different, depending on the dsPIC being used
PWM motor Dead Time
Dead Time A - B
Dead Time Info
Dead Time PWMx Active
Dead Time PWMx Inactive
Know Bugs
PWM 2 peripheral : error at compilation time
