DsPIC Block/Output Compare
Block Output Compare
Outline
Output Compare Dialog
  • Time Up and Time Down
  • Time Up ane Periode
  • Time Down and Periode
With
Interrupt Priority
Output Channels
Channels Input Type
Max/Channels
