DsPIC Block/Interface Tx-Matlab
< DsPIC Block
Revision as of 18:30, 3 May 2015 by LubinKerhuel (talk | contribs) (LubinKerhuel moved page Block/Interface Tx-Matlab to DsPIC Block/Interface Tx-Matlab: Block is a special page, creates many issues)
Interface PIC-Matlab
Watch out : When logging data for a long time usinga big buffer size, some data may be lost : As the matrix R is growing,Matlab reallocate memory when the matrix is growing. This memory allocation may take some time and for reason that are still unclear, Seral port lose some datas. Note that Matlab use Java to acces to the serail PORT. Thus, it is not optimal!
Real-Time Consideration
T_R is an approximation of time only, and shoudl be used for vewing purpose only. If you need precise data time stapm, follow the following procedure :
  • On the simulink model, make sure to not overload the UART. Check that you are sending less data than max allowed by the UART bauds. To count the number of bytes used, when using the Tx-Labview-Matlab block, add one byte for each data sent. For example sending one uint8 data takes 2 bytes, uint16 data takes 3 bytes and uint32 data takes 5 bytes.
  • Reconstruct a vector timing corresponding to the simulink's UART timing.
Forum related question
real time : http://www.kerhuel.eu/forum/viewtopic.php?f=1&t=207&p=787
