DsPIC Block/Input Capture
Block Input Capture
Interrupt Priority
Input Channels
Channels Input Type
  • 1 : is to get the High pulse duration
  • 2 : is to get the Low pulse duration
  • 3 : is to get both High and low pulse duration
  • 4 : is to get the periode using rising edge
  • 8 : is to get the periode using falling edge
  • 5 : is to get both High pulse duration and periode using rising edge
  • 10 : is to get both Down pulse duration and periode using falling edge
Max/Channels
Define max time in secondes of the largest event tu be measure by the respective channel. Safety margin in %
Changed Detected on
