DsPIC Block/Digital Output Read
< DsPIC Block
Revision as of 20:18, 26 May 2008 by 139.124.74.228 (talk) (New page: The Digtal Output get the last value written to the microcontroller pin. =Dialog Box Parameters= ==Port== *Port used ==Pin== *Pin used, start at 0 and is defined in vector form. ==Bloc...)
Port
  • Port used
Pin
