DsPIC Block/C Function Call
Block C Function Call
Call user defined C function
The C Function Call block allows to include your custom C written functions (that could contain assembly language) into the schematic. It Interfaces your functions with the MathWorks Simulink diagram. The .c file containing the code of the function should be placed in the same directory as the .mdl file. If the c file is in another directory, it must be manually added in the "Simulation Parameters -> Real time workshop -> additional C file"
C Function Call Dialog
Function Name
Global input size
Specify if the variables of the inputs are scalar (1) or vector ( >1 : array with one dimension). All different input data have the same size. they must all be either scalars nor vectors of equal dimension.
Input 1 2 3
Output Size
Size of the output variable. It can be either a scalar (1) ; neither a vector ( >1 : array with one dimension)
Output type
data type of the output data.
Sample time
-1 means inherited
Function declaration
Function call
  • %y represent blocks output
  • %u represent blocks input
