DsPIC Block/CAN Receive
< DsPIC Block
Revision as of 19:30, 3 May 2015 by LubinKerhuel (Talk | contribs) (LubinKerhuel moved page Block/CAN Receive to DsPIC Block/CAN Receive: Block is a special page, creates many issues)
Jump to: navigation, search
Block CAN Receive
Read data from a CAN bus
CAN Receive Dialog
CAN Receive Dialog
CAN Receive Dialog
Num CAN
Filter 0 and 1 Acceptance Mask / Filter 2, 3 and 4 Acceptance Mask
Message x Data Length
Acceptance Filter x
Acceptance Filter type
  • Standard or Extended
  • Standard 11 bits
  • Extended 29 bits
Output received Data Length
Output Flag New Message
Output Identifier
Output Flag Data Request To send
Receive Error Counter
Output Flag Data Lost
Information
