Syntax error in compilation
Beni
Post by Beni » Wed Aug 19, 2009 11:24 am
Hi!
I have an compilation error when try to build the examples:
### Invoking Target Language Compiler on ledsample.rtw
	tlc
	-r
	C:\0beni\matlabwork\ledsample_dspic\sources\ledsample.rtw
	C:\0beni\matlabwork\dspic\dspic.tlc
	-OC:\0beni\matlabwork\ledsample_dspic\sources
	-IC:\0beni\matlabwork\dspic
	-IC:\0beni\matlabwork\blocks
	-IC:\0beni\matlabwork\ledsample_dspic\sources\tlc
	-IC:\0beni\Programok\MATLAB\R2006a\rtw\c\tlc\mw
	-IC:\0beni\Programok\MATLAB\R2006a\rtw\c\tlc\lib
	-IC:\0beni\Programok\MATLAB\R2006a\rtw\c\tlc\blocks
	-IC:\0beni\Programok\MATLAB\R2006a\rtw\c\tlc\fixpt
	-IC:\0beni\Programok\MATLAB\R2006a\stateflow\c\tlc
	-aEnforceIntegerDowncast=1
	-aFoldNonRolledExpr=1
	-aInlineInvariantSignals=0
	-aInlineParameters=0
	-aLocalBlockOutputs=1
	-aRollThreshold=5
	-aGenerateReport=0
	-aGenCodeOnly=0
	-aRTWVerbose=1
	-aIncludeHyperlinkInReport=0
	-aLaunchReport=0
	-aForceParamTrailComments=0
	-aGenerateComments=1
	-aIgnoreCustomStorageClasses=1
	-aIncHierarchyInIds=0
	-aMaxRTWIdLen=31
	-aShowEliminatedStatements=0
	-aIncDataTypeInIds=0
	-aInsertBlockDesc=0
	-aSimulinkBlockComments=1
	-aInlinedPrmAccess="Literals"
	-aIsPILTarget=0
	-aIncludeMdlTerminateFcn=0
	-aCombineOutputUpdateFcns=0
	-aSuppressErrorStatus=0
	-aERTCustomFileBanners=0
	-aLogVarNameModifier="rt_"
	-aGenerateFullHeader=1
	-aGenerateSampleERTMain=0
	-aMatFileLogging=0
	-aMultiInstanceERTCode=0
	-aPurelyIntegerCode=0
	-aGenerateErtSFunction=0
	-aGenerateASAP2=0
	-aExtMode=0
	-aExtModeStaticAlloc=0
	-aExtModeTransport=0
	-aExtModeTesting=0
	-aTargetOS="BareBoardExample"
	-aRateGroupingCode=1
	-aRTWCAPISignals=0
	-aRTWCAPIParams=0
	-aRootIOStructures=0
	-aGMAKE_PLACE="C:\0beni\Programok\MATLAB\R2006a\rtw\bin\win32\gmake"
	-aOPTIM_GCC="-mcpu=30f4013 -O3 -fschedule-insns -fschedule-insns2 -fno-short-double"
	-aLDPICTYPE="-T C:\PROGRA~1\MICROC~1\MPLABC~1\support\dsPIC30F\gld\p30f4013.gld"
	-aLDLIBPIC="C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libpic30-coff.a  C:\PROGRA~1\MICROC~1\MPLABC~1\lib\dsPIC30F\libp30f4013-coff.a C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libc-coff.a C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libm-coff.a"
	-aPIC_INCLUDES="-I C:\PROGRA~1\MICROC~1\MPLABC~1\include"
	-aPIC_REF="30f4013"
	-aGCCPATH=""
	-p10000
Error: File: execstring Line: 1 Column: 23
Unterminated string
Error: File: execstring Line: 1 Column: 26
syntax error
I figured out that \ should be \\ and between the " " there should be no whitespace or it's a syntax error..
i use matlab r2006. Where can I set the optim_gcc and the other parameters, or how can i solve that problem?
regards,
Beni
Beni
Re: Syntax error in compilation
Post by Beni » Wed Aug 19, 2009 11:39 am
Hi!
Ok I found the solution:
I have to set at
Simulation ==> Configuration Parameters.. ==> Real-Time Workshop ==> DsPIC options
the path variables / to //
ex.:
C:\Programs\MATLAB\R2006a\rtw\bin\win32\gmake
change to:
C:\\Programs\\MATLAB\\R2006a\\rtw\\bin\\win32\\gmake
and it complies well.
regards,
Beni
Users browsing this forum: No registered users and 40 guests
