Error 0xff appears while compiling
Hey i want to import a generated c code into a matlab project but i get an error when i want to build the project (model)
I followed every step described on http://www.kerhuel.eu/RTWdsPIC/examples ... MPLAB.html , also have c32 c30 and c24 compiler installated (was automatically installed with mplab!!)
i hope that someone of u experts out there can help me! big thanks in advance!!
.) I have a log from the building process:
Command Window:
C:\Programme\MATLAB\R2006b\work\suprer_dspic\sources>C:\Programme\MATLAB\R2006b\rtw\bin\win32\gmake -f suprer.mk GENERATE_REPORT=0 ADD_MDL_NAME_TO_GLOBALS=1 MULTI_INSTANCE_CODE=0 GENERATE_ASAP2=0 TMW_EXTMODE_TESTING=0
C:\\PROGRA~1\\MICROC~1\\MPLABC~1\\bin\\pic30-gcc -c -mcpu=choose_dsPIC_Target -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\Programme\MATLAB\R2006b/simulink/include -IC:\Programme\MATLAB\R2006b/extern/include -IC:\Programme\MATLAB\R2006b/rtw/c/src -IC:\Programme\MATLAB\R2006b/rtw/c/ert -IC:\Programme\MATLAB\R2006b/rtw/c/src/ext_mode/common -IC:\Programme\MATLAB\R2006b\work\suprer_dspic\sources -IC:\Programme\MATLAB\R2006b\work -IC:\Programme\MATLAB\R2006b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~1\include suprer_main.c
gmake: *** [suprer_main.o] Error 0xff
### Real-Time Workshop build procedure for model: 'suprer' aborted due to an error.
Model error:
Error building Real-Time Workshop target for block diagram 'suprer'. MATLAB error message:
Error using ==> RTW.genMakefileAndBuild
Error(s) encountered while building model "suprer".
Command Window:
Model error:
Re: Error 0xff appears while compiling
Hi
" informations.
Try compiling an example from the example directory ! and then adapt it to your needs...
That mean that you did not selected the target in the Master block !HTL wrote:-mcpu=choose_dsPIC_Target
That's may be old pages. Please go to the wiki for more "up to dateHTL wrote:http://www.kerhuel.eu/RTWdsPIC/examples ... MPLAB.html
Thanks for the picture that help.
The system target file is selected (dspic.tlc) properly: Ok
But you did not select the PIC/dsPIC you are using in the Master block. Thus, dbl click on the master block, and select your target (for the moment, the selected target is 'Choose_dsPIC_Target', as written on the Master block)
To get sure Simulink is properly configured, you may also add the yellow block called configure simulink for dsPIC target and dbl click on it. It will check and correct missing configuration...
That's definitly not the right target ! You must choose, within the list,microcontroller your are targetting. it can be a dsPIC30f2010 or any of the given list, but not "choose_dsPIC_Target".HTL wrote:if thats not the right one which target do i have to choose?
Hey thanks i tried it yesterday but i still get an error:
Heres a code maybe theres again something wrong with the targets??
I tried everything, installing matlab again and the other tools but it still doesnt work..heres the error code if u need it and below a screenshot maybe something else is not correctly configured?
Thanks for your answers u did, hope you can figure out what the problem is!
Model configured...
### Starting Real-Time Workshop build procedure for model: suprer
### Generating code into build directory: C:\Programme\MATLAB\R2006b\work\suprer_dspic\sources
PTWarning: Source 'suprer/Digital Input' specifies that its sample time (-1) is back-inherited. You should explicitly specify the sample time of sources. You can disable this diagnostic by setting the 'Source block specifies -1 sample time' diagnostic to 'none' in the Sample Time group on the Diagnostics pane of the Configuration Parameters dialog box.
### Invoking Target Language Compiler on suprer.rtw
tlc
-r
C:\Programme\MATLAB\R2006b\work\suprer_dspic\sources\suprer.rtw
C:\Programme\MATLAB\R2006b\work\dspic\dspic.tlc
-OC:\Programme\MATLAB\R2006b\work\suprer_dspic\sources
-IC:\Programme\MATLAB\R2006b\work\dspic
-IC:\Programme\MATLAB\R2006b\work\blocks
-IC:\Programme\MATLAB\R2006b\work\suprer_dspic\sources\tlc
-IC:\Programme\MATLAB\R2006b\rtw\c\tlc\mw
-IC:\Programme\MATLAB\R2006b\rtw\c\tlc\lib
-IC:\Programme\MATLAB\R2006b\rtw\c\tlc\blocks
-IC:\Programme\MATLAB\R2006b\rtw\c\tlc\fixpt
-IC:\Programme\MATLAB\R2006b\stateflow\c\tlc
-aEnforceIntegerDowncast=1
-aFoldNonRolledExpr=1
-aInlineInvariantSignals=0
-aInlineParameters=0
-aLocalBlockOutputs=1
-aRollThreshold=5
-aGenerateReport=0
-aGenCodeOnly=0
-aRTWVerbose=1
-aIncludeHyperlinkInReport=0
-aLaunchReport=0
-aForceParamTrailComments=0
-aGenerateComments=1
-aIncHierarchyInIds=0
-aMaxRTWIdLen=31
-aShowEliminatedStatements=0
-aIncDataTypeInIds=0
-aInsertBlockDesc=0
-aSimulinkBlockComments=1
-aInlinedPrmAccess="Literals"
-aIsPILTarget=0
-aIncludeMdlTerminateFcn=0
-aCombineOutputUpdateFcns=1
-aSuppressErrorStatus=1
-aERTCustomFileBanners=1
-aLogVarNameModifier="rt_"
-aGenerateFullHeader=1
-aGenerateSampleERTMain=0
-aMatFileLogging=0
-aMultiInstanceERTCode=0
-aPurelyIntegerCode=0
-aGenerateErtSFunction=0
-aGenerateASAP2=0
-aExtMode=0
-aExtModeStaticAlloc=0
-aExtModeTransport=0
-aExtModeTesting=0
-aTargetOS="BareBoardExample"
-aRateGroupingCode=1
-aRTWCAPISignals=0
-aRTWCAPIParams=0
-aRootIOStructures=0
-aGMAKE_PLACE="C:\Programme\MATLAB\R2006b\rtw\bin\win32\gmake"
-aOPTIM_GCC="-mcpu=24fJ128GA006 -O3 -fschedule-insns -fschedule-insns2"
-aLDFLAGS="-t --report-mem -Map ../untitled.map --heap 0 -cref"
-aLDPICTYPE="-T C:\PROGRA~1\MICROC~1\MPLABC~1\support\PIC24F\gld\p24fJ128GA006.gld"
-aLDLIBPIC="C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libpic30-coff.a C:\PROGRA~1\MICROC~1\MPLABC~1\lib\PIC24F\libpPIC24Fxxx-coff.a C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libc-coff.a C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libm-coff.a"
-aPIC_INCLUDES="-I C:\PROGRA~1\MICROC~1\MPLABC~1\include"
-aPIC_REF="24fJ128GA006"
-aGCCPATH=""
-p10000
### Writing header file suprer_types.h
### Writing header file suprer.h
### Writing source file suprer.c
### Writing header file suprer_private.h
### Writing source file suprer_main.c
Embedded Coder for dsPIC V0.99a(28-Oct-2008) for Matlab R2006b.
Licence Accorded to Demo
RTWdsPIC@kerhuel.eu
Author : Lubin KERHUEL
WEBSITE : http://www.kerhuel.eu
SIRENE : 503 920 456
Facturation to :
SIRET : 503 920 456 00012
Check updates and new informations at : www.kerhuel.eu
### Processing Template Makefile: C:\Programme\MATLAB\R2006b\work\dspic\dspic_pic30_gcc.tmf
### <C:\Programme\MATLAB\R2006b\rtw\bin\win32\gmake>
### in default batch file
### suprer.mk which is generated from C:\Programme\MATLAB\R2006b\work\dspic\dspic_pic30_gcc.tmf is up to date
### Building suprer: .\suprer.bat
C:\Programme\MATLAB\R2006b\work\suprer_dspic\sources>set MATLAB=C:\Programme\MATLAB\R2006b
pic30-gcc -c -mcpu=24fJ128GA006 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\Programme\MATLAB\R2006b/simulink/include -IC:\Programme\MATLAB\R2006b/extern/include -IC:\Programme\MATLAB\R2006b/rtw/c/src -IC:\Programme\MATLAB\R2006b/rtw/c/ert -IC:\Programme\MATLAB\R2006b/rtw/c/src/ext_mode/common -IC:\Programme\MATLAB\R2006b\work\suprer_dspic\sources -IC:\Programme\MATLAB\R2006b\work -IC:\Programme\MATLAB\R2006b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~1\include suprer_main.c
pic30-gcc -c -mcpu=24fJ128GA006 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\Programme\MATLAB\R2006b/simulink/include -IC:\Programme\MATLAB\R2006b/extern/include -IC:\Programme\MATLAB\R2006b/rtw/c/src -IC:\Programme\MATLAB\R2006b/rtw/c/ert -IC:\Programme\MATLAB\R2006b/rtw/c/src/ext_mode/common -IC:\Programme\MATLAB\R2006b\work\suprer_dspic\sources -IC:\Programme\MATLAB\R2006b\work -IC:\Programme\MATLAB\R2006b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~1\include suprer.c
pic30-ld -t --report-mem -Map ../untitled.map --heap 0 -cref -T C:\PROGRA~1\MICROC~1\MPLABC~1\support\PIC24F\gld\p24fJ128GA006.gld -o ..\../suprer.coff suprer_main.o suprer.o rtwlib.a C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libpic30-coff.a C:\PROGRA~1\MICROC~1\MPLABC~1\lib\PIC24F\libpPIC24Fxxx-coff.a C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libc-coff.a C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libm-coff.a
C:\Programme\Microchip\MPLAB C30\bin\bin/pic30-coff-ld.exe: cannot open linker script file C:\PROGRA~1\MICROC~1\MPLABC~1\support\PIC24F\gld\p24fJ128GA006.gld: No such file or directory
gmake: *** [..\../suprer.coff] Error 0xff
Simulink configuration is Ok. That a problem about the installation of the Microchip C30 compiler. There is 2 version of this compiler on the microchip website. (As fas as I remember, C30 for Pic24 and C30 for dsPIC30f). Install them booth.
Make sure that this file exist :
It should works properly then !HTL wrote:C:\PROGRA~1\MICROC~1\MPLABC~1\support\PIC24F\gld\p24fJ128GA006.gld: No such file or directory
