I'm attempting to run one of the example simulink files (the Data_Login_Matlab one)
I try to double click on "Configure Model for dsPIC Target" and nothing happens, when I try to manually change all the target info to 'dsPIC30F6010A' I still end up missing some.
Any ideas?
Configure Model won't open
Re: Configure Model won't open
To change the target to 30f6010A, open the "dsPIC MASTER" block.
You will find the list of the supported chips (exhaustive list can be found on the download page).
The dialog unexpectedly closed when the target is modified. You have to re-open it to modify others parameters (quartz use...)
This configures some simulink parameters (fixed step solver etc...) but do not change the target.rmiller wrote:Configure Model for dsPIC Target
