error compilation
Re: error compilation
Hi Elmay,
Unexpected problem, easily solved however !
It happens that your model name pwm.mdl generates C code files with the same name (i.e. pwm.c and pwm.h). But the model must include another files which is pwm.h from the microchip library. Here, the generated file pwm.h shadows the microchip library file pwm.h.
Workaround:
Rename your simulink file into pwm_test.mdl for example. Compilation is then Ok.
Others ticks : a model time step of 1/100000 which is 1us is pretty fast for the microcontroller ! You should try with a 1ms or 250us time step for example ! This time step has no effects on the max PWM frequency you can achieved.
I am also not certain that PWM blocks is configured as you expected it.
Here, the period id set to (1000/PWM*0.41943) with PWM = 65534 thus you'll get a period of 6.4ms and duty cycle (500/1000 = 50%) of 3.2ms.
Please try to copy/past from the matlab workspace the errors you obtain using the forum Code function. Try to add to the model you posted a screenshot of it. It may help other users and I may respond faster.
Workaround:
error compilation
I make changes on this model but still error appears
thank you
thank you
- matlab workspace errors.doc
- (34.5 KiB) Downloaded 1461 times
- pwm_test.mdl
- (26.98 KiB) Downloaded 1437 times
Working version attached.
LubinLubinKerhuel wrote:Please try to copy/past from the matlab workspace the errors you obtain using the forum Code function. Try to add to the model you posted a screenshot of it. It may help other users and I may respond faster.
- pwm_test.mdl
- inlining parameters + remove serail external interface (not fonctionnal yet)
- (28.62 KiB) Downloaded 1388 times
Model configured...
### Starting Real-Time Workshop build procedure for model: pwm_test
### Generating code into build directory: D:\Documents and Settings\ELMAY\Bureau\pwm_test_dspic\sources
PTPTPNumber of I/O PINs used : 0
TTPTPTTTWarning: Could not find an exact (case-sensitive) match for 'dsPIC_PWM_Motor_callback_InitMask'.
D:\Documents and Settings\ELMAY\Mes documents\Downloads\DSPIC_DOC\dspic\blocks\dsPIC_PWM_motor_callback_InitMask.p is a
case-insensitive match and will be used instead.
You can improve the performance of your code by using exact
name matches and we therefore recommend that you update your
usage accordingly. Alternatively, you can disable this warning using
warning('off','MATLAB:dispatcher:InexactCaseMatch').
This warning will become an error in future releases.
TPTTPTPTT### Invoking Target Language Compiler on pwm_test.rtw
tlc
-r
D:\Documents and Settings\ELMAY\Bureau\pwm_test_dspic\sources\pwm_test.rtw
D:\Documents and Settings\ELMAY\Mes documents\Downloads\DSPIC_DOC\dspic\dspic\dspic.tlc
-OD:\Documents and Settings\ELMAY\Bureau\pwm_test_dspic\sources
-ID:\Documents and Settings\ELMAY\Mes documents\Downloads\DSPIC_DOC\dspic\dspic
-ID:\Documents and Settings\ELMAY\Mes documents\Downloads\DSPIC_DOC\dspic\blocks
-ID:\Documents and Settings\ELMAY\Bureau\pwm_test_dspic\sources\tlc
-ID:\Program Files\MATLAB\R2009b\rtw\c\tlc\mw
-ID:\Program Files\MATLAB\R2009b\rtw\c\tlc\lib
-ID:\Program Files\MATLAB\R2009b\rtw\c\tlc\blocks
-ID:\Program Files\MATLAB\R2009b\rtw\c\tlc\fixpt
-ID:\Program Files\MATLAB\R2009b\stateflow\c\tlc
-aEnforceIntegerDowncast=1
-aFoldNonRolledExpr=1
-aInlineInvariantSignals=1
-aInlineParameters=0
-aLocalBlockOutputs=0
-aRollThreshold=5
-aInitFltsAndDblsToZero=1
-aForceBlockIOInitOptimize=0
-aGenerateReport=0
-aGenCodeOnly=0
-aRTWVerbose=1
-aIncludeHyperlinkInReport=0
-aLaunchReport=0
-aGenerateTraceInfo=0
-aForceParamTrailComments=0
-aGenerateComments=1
-aIncHierarchyInIds=0
-aMaxRTWIdLen=31
-aShowEliminatedStatements=0
-aIncDataTypeInIds=0
-aInsertBlockDesc=0
-aIgnoreTestpoints=0
-aSimulinkBlockComments=1
-aInlinedPrmAccess="Literals"
-aIsPILTarget=0
-aIncludeMdlTerminateFcn=0
-aCombineOutputUpdateFcns=1
-aSuppressErrorStatus=0
-aERTCustomFileBanners=1
-aLogVarNameModifier="rt_"
-aGenerateFullHeader=1
-aGenerateSampleERTMain=0
-aMatFileLogging=0
-aMultiInstanceERTCode=0
-aPurelyIntegerCode=0
-aPortableWordSizes=0
-aGenerateErtSFunction=0
-aGenerateASAP2=0
-aExtMode=1
-aExtModeStaticAlloc=0
-aExtModeTransport=0
-aExtModeTesting=0
-aTargetOS="BareBoardExample"
-aRateGroupingCode=1
-aRTWCAPISignals=0
-aRTWCAPIParams=0
-aRootIOStructures=0
-aGMAKE_PLACE="D:\PROGRA~1\MATLAB\R2009b\bin\win32\gmake"
-aOPTIM_GCC="-mcpu=30f3010 -O3 -fschedule-insns -fschedule-insns2 -merrata=exch -mlarge-data"
-aLDFLAGS=" -Xlinker -t -Xlinker --report-mem -Xlinker -Map=../untitled.map -Xlinker --heap=0 -Xlinker -cref"
-aLDPICTYPE=" -Xlinker --script=D:\PROGRA~1\MICROC~1\mplabc30\v3.25\support\dsPIC30F\gld\p30f3010.gld"
-aLDLIBPIC=" D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libpic30-coff.a D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\dsPIC30F\libp30f3010-coff.a D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libc-coff.a D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libm-coff.a"
-aPIC_INCLUDES=" -I D:\PROGRA~1\MICROC~1\mplabc30\v3.25\include"
-aPIC_REF="30f3010"
-aGCCPATH=""
-aProtectedModelReferenceTarget=0
-p10000
### Writing header file pwm_test_types.h
### Writing header file pwm_test.h
### Writing source file pwm_test.c
### Writing header file pwm_test_private.h
### Writing source file pwm_test_data.c
### Writing source file pwm_test_main.c
### Generating TLC interface API.
### Creating data type transition file pwm_test_dt.h
Embedded Coder for dsPIC V3.4b(14-Jan-2011) for Matlab R2009b.
Licence Accorded to Demonstration Version
RTWdsPIC@kerhuel.eu
Author : Lubin KERHUEL
WEBSITE : http://www.kerhuel.eu/wiki
SIRENE : 503 920 456
SIRET : 503 920 456 00012
Facturation to : Demo
Demo
Lubin KERHUEL
1, rue Alfred Fredet
38100 Grenoble
FRANCE
Check updates and new informations at : www.kerhuel.eu
### Processing Template Makefile: D:\Documents and Settings\ELMAY\Mes documents\Downloads\DSPIC_DOC\dspic\dspic\dspic_pic30_gcc.tmf
### Creating pwm_test.mk from D:\Documents and Settings\ELMAY\Mes documents\Downloads\DSPIC_DOC\dspic\dspic\dspic_pic30_gcc.tmf
### Building pwm_test: "D:\PROGRA~1\MATLAB\R2009b\bin\win32\gmake" -f pwm_test.mk GENERATE_REPORT=0 MULTI_INSTANCE_CODE=0 PORTABLE_WORDSIZES=0 GENERATE_ASAP2=0 TMW_EXTMODE_TESTING=0
''pic30-gcc -c -mcpu=30f3010 -O3 -fschedule-insns -fschedule-insns2 -merrata=exch -mlarge-data -O -I. -I..\.. -ID:\PROGRA~1\MATLAB\R2009b/simulink/include -ID:\PROGRA~1\MATLAB\R2009b/extern/include -ID:\PROGRA~1\MATLAB\R2009b/rtw/c/src -ID:\PROGRA~1\MATLAB\R2009b/rtw/c/ert -ID:\PROGRA~1\MATLAB\R2009b/rtw/c/src/ext_mode/common -ID:\DOCUME~1\ELMAY\Bureau\pwm_test_dspic\sources -ID:\DOCUME~1\ELMAY\Bureau -ID:\DOCUME~1\ELMAY\Bureau\Simulink_PWM -I D:\PROGRA~1\MICROC~1\mplabc30\v3.25\include pwm_test_data.c
''pic30-gcc -c -mcpu=30f3010 -O3 -fschedule-insns -fschedule-insns2 -merrata=exch -mlarge-data -O -I. -I..\.. -ID:\PROGRA~1\MATLAB\R2009b/simulink/include -ID:\PROGRA~1\MATLAB\R2009b/extern/include -ID:\PROGRA~1\MATLAB\R2009b/rtw/c/src -ID:\PROGRA~1\MATLAB\R2009b/rtw/c/ert -ID:\PROGRA~1\MATLAB\R2009b/rtw/c/src/ext_mode/common -ID:\DOCUME~1\ELMAY\Bureau\pwm_test_dspic\sources -ID:\DOCUME~1\ELMAY\Bureau -ID:\DOCUME~1\ELMAY\Bureau\Simulink_PWM -I D:\PROGRA~1\MICROC~1\mplabc30\v3.25\include pwm_test_main.c
''pic30-gcc -c -mcpu=30f3010 -O3 -fschedule-insns -fschedule-insns2 -merrata=exch -mlarge-data -O -I. -I..\.. -ID:\PROGRA~1\MATLAB\R2009b/simulink/include -ID:\PROGRA~1\MATLAB\R2009b/extern/include -ID:\PROGRA~1\MATLAB\R2009b/rtw/c/src -ID:\PROGRA~1\MATLAB\R2009b/rtw/c/ert -ID:\PROGRA~1\MATLAB\R2009b/rtw/c/src/ext_mode/common -ID:\DOCUME~1\ELMAY\Bureau\pwm_test_dspic\sources -ID:\DOCUME~1\ELMAY\Bureau -ID:\DOCUME~1\ELMAY\Bureau\Simulink_PWM -I D:\PROGRA~1\MICROC~1\mplabc30\v3.25\include pwm_test.c
''pic30-gcc -mcpu=30f3010 pwm_test_data.o pwm_test_main.o pwm_test.o D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libpic30-coff.a D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\dsPIC30F\libp30f3010-coff.a D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libc-coff.a D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libm-coff.a -o ..\../pwm_test.cof -Xlinker --script=D:\PROGRA~1\MICROC~1\mplabc30\v3.25\support\dsPIC30F\gld\p30f3010.gld -Xlinker -t -Xlinker --report-mem -Xlinker -Map=../untitled.map -Xlinker --heap=0 -Xlinker -cref
d:\program files\microchip\mplabc30\v3.25\bin\bin\..\bin/pic30-coff-ld.exe: mode pic30_coff
pwm_test_data.o
pwm_test_main.o
pwm_test.o
(D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libpic30-coff.a)crt0_standard.o
(D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libpic30-coff.a)data_init_standard.o
(D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\dsPIC30F\libp30f3010-coff.a)ConfigIntTimer1.o
(D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\dsPIC30F\libp30f3010-coff.a)SetDCMCPWM.o
(D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\dsPIC30F\libp30f3010-coff.a)ConfigIntMCPWM.o
(D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\dsPIC30F\libp30f3010-coff.a)OpenMCPWM.o
(D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libc-coff.a)memset.o
(D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libc-coff.a)puts.o
(D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libc-coff.a)fputc.o
(D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libc-coff.a)stdclean.o
(D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libc-coff.a)fseek.o
(D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libc-coff.a)fflush.o
(D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libc-coff.a)flsbuf.o
(D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libc-coff.a)fclose.o
(D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libc-coff.a)buf.o
(D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libc-coff.a)tfiles.o
(D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libc-coff.a)errno.o
(D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libm-coff.a)fne.o
(D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libm-coff.a)addsf3.o
(D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libm-coff.a)mulsf3.o
(D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libm-coff.a)fgtge.o
(D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libm-coff.a)floatsisf.o
(D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libm-coff.a)fcompare.o
(D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libm-coff.a)funpack2.o
(D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libm-coff.a)futil.o
(D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libm-coff.a)fpack.o
(D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libm-coff.a)funpack.o
(d:/program files/microchip/mplabc30/v3.25/bin/bin/../../lib\libpic30-coff.a)lseek.o
(d:/program files/microchip/mplabc30/v3.25/bin/bin/../../lib\libpic30-coff.a)write.o
(d:/program files/microchip/mplabc30/v3.25/bin/bin/../../lib\libpic30-coff.a)close.o
(d:/program files/microchip/mplabc30/v3.25/bin/bin/../../lib\libpic30-coff.a)remove.o
(d:/program files/microchip/mplabc30/v3.25/bin/bin/../../lib\libpic30-coff.a)sbrk.o
(d:/program files/microchip/mplabc30/v3.25/bin/bin/../../lib\libpic30-[img][code]
(d:/program files/microchip/mplabc30/v3.25/bin/bin/../../lib\libpic30-coff.a)brk.o
stdclean.o: Link Error: Could not allocate section .bss, size = 1026 bytes, attributes = bss
Link Error: Could not allocate data memory
gmake: *** [..\../pwm_test.cof] Error 255
### Real-Time Workshop build procedure for model: 'pwm_test' aborted due to an error.
Could you test with the model I uploaded on the forum ?
