PIC32 Bootloader memory offset
mlove
Post by mlove » Thu Aug 12, 2010 10:14 am
Hi There,
I was wanting to use the PIC32 Bootloader to upload code for en embedded application. Use of the bootloader requires that the start vector for the application sofware has a memory offset added to the code and uses a custom set of *.ld files and bootloader memory file. Is there a way to edit the blockset /dspic target in order to add this ofset into the build sequence? Also, how could the scripts be modified to pull in the other custom files required?
Matthew Love
mlove
Re: PIC32 Bootloader memory offset
Post by mlove » Mon Aug 16, 2010 10:52 am
Hi all, It was just a matter of changing the procdefs.ld file for the device being used and then the target generates the correct application code for use with the MC bootloader.
Matthew
Users browsing this forum: Google [Bot] and 17 guests
