I2C on PIC32
edlaurence
I2C on PIC32
Post by edlaurence » Mon Aug 02, 2010 12:34 pm
Hi again Lubin,
Looks like my last thread got hijacked so here it is again....
I'm having some problems building a model to communicate between a PIC32 (32MX360F256L) and a Bosch accelerometer (BMA180) using an I2C bus for a heli autopilot application. Looking through the posts on the forum I think this problem was found by another user earlier this year and seems to fall over at the following point during the build..
dsPIC_32MX360F256L_AccelI2C.c:1: warning: Compiler option ignored due to lite-mode limitations
dsPIC_32MX360F256L_AccelI2C.c: In function `dsPIC_32MX360F256L_AccelI2C_step':
dsPIC_32MX360F256L_AccelI2C.c:48: error: union has no member named `MI2C1IF'
dsPIC_32MX360F256L_AccelI2C.c:55: error: union has no member named `MI2C1IF'
dsPIC_32MX360F256L_AccelI2C.c:58: error: union has no member named `MI2C1IF'
dsPIC_32MX360F256L_AccelI2C.c:68: error: union has no member named `MI2C1IF'
dsPIC_32MX360F256L_AccelI2C.c:71: error: union has no member named `MI2C1IF'
dsPIC_32MX360F256L_AccelI2C.c:78: error: union has no member named `MI2C1IF'
dsPIC_32MX360F256L_AccelI2C.c:81: error: union has no member named `MI2C1IF'
dsPIC_32MX360F256L_AccelI2C.c:93: error: union has no member named `MI2C1IF'
dsPIC_32MX360F256L_AccelI2C.c:96: error: union has no member named `MI2C1IF'
dsPIC_32MX360F256L_AccelI2C.c:103: error: union has no member named `MI2C1IF'
dsPIC_32MX360F256L_AccelI2C.c:106: error: union has no member named `MI2C1IF'
dsPIC_32MX360F256L_AccelI2C.c:118: error: union has no member named `MI2C1IF'
dsPIC_32MX360F256L_AccelI2C.c:121: error: union has no member named `MI2C1IF'
dsPIC_32MX360F256L_AccelI2C.c:128: error: union has no member named `MI2C1IF'
dsPIC_32MX360F256L_AccelI2C.c:131: error: union has no member named `MI2C1IF'
dsPIC_32MX360F256L_AccelI2C.c:142: error: union has no member named `MI2C1IF'
dsPIC_32MX360F256L_AccelI2C.c:145: error: union has no member named `MI2C1IF'
dsPIC_32MX360F256L_AccelI2C.c:162: error: union has no member named `MI2C1IF'
dsPIC_32MX360F256L_AccelI2C.c:165: error: union has no member named `MI2C1IF'
gmake: *** [dsPIC_32MX360F256L_AccelI2C.o] Error 1
### Real-Time Workshop build procedure for model: 'dsPIC_32MX360F256L_AccelI2C' aborted due to an error.
C32 Compiler found
C32 Compiler found
C32 Compiler found
I saw that you intended to take a look at the I2C blockset for PIC32F and was wondering if you had managed to make any progress on this issue? If you need any info from me please let me know.
Many thanks,
Ed Laurence
resodad
Re: I2C on PIC32
Post by resodad » Tue Apr 03, 2012 9:21 pm
I've got the same problem.
I2C_test_simple2.mdl
(29.83 KiB) Downloaded 2289 times
i2cBuildError.txt
matlab output
(4.38 KiB) Downloaded 2279 times
resodad
Re: I2C on PIC32
Post by resodad » Wed Apr 04, 2012 2:24 pm
All,
This belongs in the BUG REPORTS forum.
I will re-post there.
adina728
Re: I2C on PIC32
Post by adina728 » Mon Dec 24, 2012 5:51 am
Nice Post...Thanks for the info
looking nice
Users browsing this forum: No registered users and 19 guests
