Error for having multiple dsPIC Master blocks
bmairs
Post by bmairs » Fri Jul 30, 2010 11:23 pm
I have a model that contains only one dsPIC Master block from your blockset and yet I get the error for having multiple master blocks (this error should also say "found" instead of "find"). I've attached the model here. From removing each block at a time and checking for errors, it seems like the code thinks that the ECAN1 TX block is another master block for whatever reason.
Main.mdl
(117.71 KiB) Downloaded 876 times
