TECHNICAL WIKI
Release Notes
PIC 24FPIC 32F**PIC 30FPIC 30FPIC 33FJ GPPIC 33FJ MCPIC 33FJ GPPIC 33FJ MC*
24fJ128GA006
32MX360F256L
30f2010
30f5011
33fJ128GP206
33fJ256MC510
33fj128GP202
33fj128MC202
24fJ128GA008
32MX360F512L
30f2011
30f5013
33fJ128GP306
33fJ256MC710
33fj128GP204
33fj128MC204
24fJ128GA010
32MX460F256L
30f2012
30f5015
33fJ128GP310
33fJ64MC506
33fj128GP802
33fj128MC802
24fJ64GA006
32MX460F512L
30f3010
30f5016
33fJ128GP706
33fJ64MC508
33fj128GP804
33fj128MC804
24fJ64GA008
32MX775F256L
30f3011
30f6010
33fJ128GP708
33fJ64MC510
33fj32GP302
33fj32MC302
24fJ64GA010
32MX775F256L
30f3012
30f6011
33fJ128GP710
33fJ64MC706
33fj32GP304
33fj32MC304
24fJ96GA006
32MX795F512L
30f3013
30f6012
33fJ256GP506
33fJ64MC710
33fj64GP202
33fj64MC202
24fJ96GA008
32MX320
30f3014
30f6013
33fJ256GP510
33fJ128MC506
33fj64GP204
33fj64MC204
24fJ96GA010
32MX340
30f4011
30f6014
33fJ256GP710
33fJ128MC510
33fj64GP802
33fj64MC802
24fJ16GA002
30f4012
30f6015
33fJ64GP206
33fJ128MC706
33fj64GP804
33fj64MC804
24fJ32GA002
30f4013
33fJ64GP306
33fJ128MC708
33fJ64GP310
33fJ128MC710
33fJ64GP706
24fJ16GA004
33fJ64GP708
24fJ32GA002
33fJ64GP710
  • a bug were repported for PIC32 : problem appears when configuring with a fast clock (80Mhz) The problem is fixed by adding a c line code : SYSTEMConfigPerformance(80000000). This bug has not been checked yet.
  • 10/09/2012: v3.7e
    • PWM motor : added Fault protection option
  • 09/01/2012: v3.7c
  • 09/01/2012: v3.7c
  • 19/12/2011: v3.7b
    • Minor bug correction : ADC block sometimes did not store parameters of output format (required to set parameters each time model were opened).
    • Bugfix: MPLAB project creation : try to correct some bugs detailed in </forum/topic/457/> (Not tested yet on model provided by Bryant)
  • 08/10/2011: v3.7
  • 11/09/2011: v3.6c
  • 07/09/2011: v3.6b
    • Bugfix : MPLAB X was supported only on Win32. Now supported on both Win32 and Win64
  • 25/07/2011: v3.6
    • Suport MPLAB X : Generated C code files can be opened as a project within the new MPLAB X IDE (tested with Beta 0.6)
    • Chip added : 256GP710A
  • 15/05/2011: v3.5b
    • Chip added : 64MC204, 128MC204, 128GP202, 32MC202, 32MC204, 16MC304
  • 21/04/2011: v3.5
  • 01/03/2011: v3.4c
    • rs232gui : adding custom speed rate and custom port com (work with MACs)
    • Examples updates
  • 13/01/2011: v3.4b
  • 30/12/2010: v3.4
    • Input Capture : ICxMax value corresponded to the max time defined including the margin (10% by default). Now Corrected (ICxMAX = max time without the margin)
    • Change Notification : CNxMax value corresponded to the max time defined including the margin (10% by default). Now Corrected (CNxMAX = max time without the margin)
    • External Interrupt : INTxMax value corresponded to the max time defined including the margin (10% by default). Now Corrected (INTxMAX = max time without the margin)
    • 33f chips : improved algorithm to find best choice for pre and post diviser for PLL configuration
  • 24/12/2010: V3.3c
  • 05/12/2010: v3.3b
    • MPLAB project : Try to create projects with relative path if it is possible
  • 21/11/2010: v3.3a
  • 8/11/2010: V3.3
    • New : Create MPLAB project file that make easy the integration of the generated code into MPLAB. It allow to re-compile it, to use MPLAB tool (like debuger) and add your c code.
    • Corrected bug:
  • 23/07/2010: V3.2c
    • Corrected bug : it was impossible to open a model if the compiler used for that model were missing
    • Corrected bug : on some systems, GMAKE was not find automatically
    • Stop support MATLAB 2006a and MATLAB 2006b. Updating theses versions may be possible on demand ; please send email : [adresse e-mail retirée].
  • 31/03/2010: V3.2b
    • Corrected missing files in V3.2 just released make it unworkable on some systems !
  • 28/03/2010: V3.2
  • 17/11/2009: V3.1
  • 26/09/2009: V3.0b
  • 26/09/2009: V3.0
    • Bug : in some matlab version (at least 2009a), an error appears : Corrupted package making the whole blockset unworkable. It is now corrected
    • change version numbering
  • 04/09/2009: V0.99h
    • Bug : PWM for chip with 1 PWM had bug (since blockset revision 0.99g)
  • 08/07/2009: V0.99g
  • 04/06/2009: V0.99f
    • Better error report : messages easier to understand
    • Bug corrected : Input Capture 7 and 8 on dsPIC with remappable pins (typically 33f) did not work. Repaired now.
  • 04/06/2009: V0.99e
    • rs232gui : improved robustess
    • Bug corrected : ADC on some dsPIC : now force AD1PCFGH to 0 when no digital output are used (instead of leaving its default value that should be 0 however)
    • bug corrected : SPI2 now can works with the interrupt block
  • 19/04/2009: V0.99d
    • 2 chips added : 32MX360F256L and 32MX460F256L.
  • 12/03/2009 V0.99c
    • Automatic timer setting is improved. Watch out : Peripheral max timer value may have change (typically, minus 1)
    • Correction : max AN value is set to 1023 instead of 1024 for 10 bits conversion and 2047 instead of 2048 for 12 bit ADC conversion
  • 01/02/2009: V0.99b
    • Peripheral added on PIC32 chip : Output Compare (OC), Input Capture (IC), External Interrupt (EI)
    • added 4 chip...
  • 28/10/2008: V0.99a
    • 20 Chips added for experimental use: 33fj64GP802, 33fj128GP802, 33fj32GP302, 33fj64GP202, 33fj128GP202, 33fj64GP804, 33fj128GP804, 33fj32GP304, 33fj64GP204, 33fj128GP204, 33fj64MC802, 33fj128MC802, 33fj32MC302, 33fj64MC202, 33fj128MC202, 33fj64MC804, 33fj128MC804, 33fj32MC304, 33fj64MC204, 33fj128MC204. Add of the Mapping_PIN block for the remappable peripheral function available on theses chips. PWM Motor block NOT WORKING YET on theses MC chip !
  • 16/09/2008 : V0.98fe
  • 02/09/2008 : V0.98fc
  • 09/08/2008 : V0.98f
  • 15/07/2008 : V0.98e
    • Corrected Bug : Typo bug on PLLODIF factor for configuration of PIC32f.
  • 18/06/2008 : V0.98d
    • Corrected Bug : Peripheral using commun PIN with ADC Channel between [16 - 31] or ADC Channel between [16 - 31] may not be configured properly.
    • Corrected Bug : UART 1 and UART 2, if both used on a model did not worked with interrupt.
    • Corrected Bug : SPI 1 and SPI 2, if both used on a model, did not worked with interrupt
    • Corrected Bug : External Interrupt peripheral did not worked when more than one external Interrupt channel were used.
    • Corrected Bug : ADC of Chip 33f did not worked when using more than one channel
    • Corrected Bug : UART when used with interrupt may corrupt data when used with buffer size larger than 256 bytes.
    • Solved Problem when upgrading the blockset : Script to update model created with oldest blockset version is not working properly.
    • New : Early Support for Pic32 (UART, ADC, digital In/out are supported ; others peripheral are comming next)
    • Added : PIC32MX360F512L, PIC32MX460F512L
    • Works with the last version of the Microchip dsPIC and PIC24 C compiler (v3.10) and with the PIC32 compiler (v1.02) Updating your compiler is necessary ! (download from the microchip website)
    • PIC 24f : Not need anymore to modify Generic.h file.
    • UART Rx Tx peripheral : you can choose to use this peripheral using interrupt and lets you define the internal buffer for Tx and Rx. It Allows to send or receive bursts of data containing more than 4 bytes (internal peripheral buffer)
    • C30 compiler can now be installed in the directory : 'C:\Programmi\Microchip\MPLAB C30' (for italian I guess)
    • SPI block : Add Sample Time option ; Add possiblity to reconfigure SPI bus speed (allow to get 2 component working at different speed on the bus)
    • UART Tx block : Corrected bug : possibility to send vector
    • I2C : New peripheral to test
    • CAN : New peripheral to test. Note that ECAN is not done yet. If you are interrested for the ECAN peripheral, ask for on the forum.
    • Corrected bug : The Time Step time refference based on timer1 was too high (get a typical time error of 1/10000). The calcul is exact now.
    • Corrected bug : C function Call did not work properly when more than one input was defined.
    • Blocks with sample time can takes 2 parameters for the sample time like others Simulink blockset : [SampleTime Offset] (see simulink help about sample time). When using only one parameters, the offset is 0. The offset could not be defined in previous blockset version.
    • Corrected bug : Only Timer 2 or 3 can be assigned to the peripheral Output Compare (OC) and Input Compare (IC). Timer assignation is automatic and now include this constraint.
    • Added : 33FJ64GP206, 33FJ128GP206, 33FJ64GP306, 33FJ128GP306, 33FJ64GP310, 33FJ128GP310, 33FJ256GP506, 33FJ256GP510, 33FJ64GP708, 33FJ128GP708, 33FJ64MC506, 33FJ128MC506, 33FJ256MC510, 33FJ64MC508, 33FJ128MC510, 33FJ256MC710*, 33FJ64MC510, 33FJ128MC706, 33FJ64MC706, 33FJ128MC708, 33FJ64MC710, 33FJ128MC710
    • Know BUG : Output Compare PWM generation does not work when Power Save mode is activated on 30f4013 and probably on others chips!
    • Corrected bug : The PLL calculation to achieve the desired MIPS did not work and generate an error on dsPIC 33f chips.
    • Added : 30F3014, 30F5011, 30F5013, 30F5015, 30F5016, 30F6010A, 24FJ96GA006, 24FJ128GA006, 24FJ64GA006, 24FJ64GA008, 24FJ96GA008, 24FJ128GA008
    • Corrected bugs :
    • Added dsPIC 33f : 33fJ64GP710, 33fJ128GP710, 33fJ256GP710
    • Bugfix : Master block sometimes lose its data when opening the model
    • Bugfix : block Uart Rx stopped receiving if overrun occure
    • Bugfix : Master block lose its data when opening the block dialog.
---- admin Template:blocksetVersion Template:blocksetDate Template:blocksetNbrChips Template:picList
