TECHNICAL WIKI
IMU sensors : 1 accelerometer MMA7260 from freescale (3 axis) coupled with 2 rate gyros ADIS16080 from analog device (1 axis each)
One rate gyro (ADIS 16080) with the simple material used for soldering. Thin wires come from a washing machine motor's coil.
  • Θ\Theta the absolute pitch angle and q the pitch angular rate.
Θ̂(t)=∫t0tq(t)dt+Θ(t0)\hat \Theta(t) = \int_{t_0}^t{q(t) dt}+\Theta(t_0)
  • Φ\Phi the absolute roll angle and p the roll angular rate.
Φ̂(t)=∫t0tp(t)dt+Φ(t0)\hat \Phi(t) = \int_{t_0}^t{p(t) dt} + \Phi(t_0)
Let's consider:
Using the acceleration vector (i.e. gravity) measured with the accelerometers, we get the Θ\Theta and Φ\Phi angles :
  • Θ̂=arctan⁡(azax)\hat \Theta= \arctan \left( \frac{a_z}{a_x} \right)
  • Φ̂=arctan⁡(azay)\hat \Phi = \arctan \left( \frac{a_z}{a_y} \right)
fig:IMU_SensorSchematic This IMU use three MEMS sensors : One Three axial analog accelerometer MMA7260QT and two one axis rate gyro ADIS16080 with SPI digital bus interface. The 3 axes accelerometer is powered by the 2.5V analog output reference generated by the 'Y axis' rate gyro component
  • model time-step is 1ms
block. All data cannot be sent; there will be missing data thus this model is useful to check every component is working only.]] The model IMU_LogData is compiled and the generated .hex file is loaded into the dsPIC (using the bootloader tinybld). The model sampling time is 1 Khz, corresponding to the time-step of 1ms. During 1ms, the UART can send 11,52 bytes when configured at 115200 bps (taking into account the start and stop bits). We log 5 int16 data that is a total of 10 bytes. The multiplexing protocol of the Tx Output Multiplexed for Matlab-Labview block]] adds one byte for each variable sent. Thus, the model should transmit 15 bytes through the UART at each time step. Because the simulink model try to send more than 11 bytes per time-step, some data will not be sent and will be lost. The Intelligent Spreading option will spread the data loss over all channels allowing to view all curves on the graph (If not checked, the two last channels may never be sent).
 >> [R T] = ``padr``(Rn,1,t_Rn);     % remove NaN values
 >> datas = [T R]';
 >> save mydatafile datas;
Tx Output
Tx Output
block. The UART buffer do not overflow with this mode, because 9 bytes are sent and the 115200bpd UART speed allow to send 11,52 bytes in one 1ms time-step. Thus all data are successfully transmitted to matlab. Logged data can feed a simulink simulation.]]
R = reshape(R,11,n); % reshape : from vector to a matrix of 11 column
idxError = find(R(1,:) ~= 55)  % Check data integrity
if ~isempty(idxError)
     error('Data corrupted')
%% Reconstruct Raw data as received through the SPI bus
RawGyro_Y = R(2,:)*2^8 + R(3,:);
RawAccel_Y = R(4,:)*2^8 + R(5,:);
RawAccel_Z = R(6,:)*2^8 + R(7,:);
RawGyro_X = R(8,:)*2^8 + R(9,:);
RawAccel_X = R(10,:)*2^8 + R(11,:);
T = [0:.001:(length(RawGyro_Y)-1)*.001];
IMU Data fusion algorithms
Downloaded
Downloaded
at the bottom of this page.]]
Simulation with real data
  • The 0.08Hz first order low pass filter transfer function for the accelerometer is :
Lp(s)=0.5s+0.5Lp(s) = \frac{0.5}{s+0.5}
  • The 0.08Hz first order High pass filter transfer function for the rate gyro is :
Hp(s)=ss+0.5Hp(s) = \frac{s}{s+0.5}
Int(s)=1314*s+314sInt(s) = \frac{1}{314} * \frac{s+314}{s}
  • For the rate gyro, we obtain the simplification :
Hp(s)Int(s)=ss+0.51314s+314s=1314s+314s+0.5Hp(s) * Int(s) = \frac{s}{s+0.5} * \frac{1}{314} * \frac{s+314}{s} = \frac{1}{314} * \frac{s+314}{s+0.5}
  • The high pass filter is:
Hp2(s)=s2(s+0.2)2Hp_2(s) = \frac{s^2}{(s+0.2)^2}
Lp2(s)=1−Hp2(s)=0.4s+0.02(s+0.2)2Lp_2(s) = 1 - Hp_2(s) = \frac{0.4s + 0.02}{(s+0.2)^2}
1s*s2(s+0.2)2=s(s+0.2)2\frac{1}{s} * \frac{s^2}{(s+0.2)^2} = \frac{s}{(s+0.2)^2}
State Space Approach
The state space structure tracks the rate gyro bias and estimate the angle by integrating the unbiased gyro.
  • Simulink models
    • IMU_Simulation.mdl
    • IMU_Simulation_FxdPts.mdl
  • m script
    • Extract_RawDatas.m
    • Script_Kalman.m
    • Caracterisation_Capteurs.m
  • mat files
    • RawDatas_Dynamic_Calibration_40se.mat : Raw data received from the dsPIC
    • Simulink_Static.mat
    • Simulink_Static_60s.mat
Implementation on a dsPIC
Complementary Filter Order 1
This model implements the complementary filter on the dsPIC and sends the result to matlab. It has the same behaviours as the simulated filter.
The IMU_ComplementaryFilter simulink model is a 'copy-past' mixture made of the IMU_LogData 'data management' part with the IMU_simu_RealData model tuned and optimize filter. This model implements the complementary filter on the dsPIC and sends the result to matlab. It will have the same behaviours of the simulated filter.
Fixed point
  • it takes a roll angle, then
Electronic board evolution
Extended IMU algorithm
This IMU is being tested onboard a Remote Control (RC) flying wing. It is destined to become an important part of the autopilot currently under development. For more information, see page :
Acknowledgement
Category:Example
