TECHNICAL WIKI
DsPIC Block/Rx Input
Block UART Rx Input
Block UART Rx Input
UART Rx Dialog
UART Rx Dialog
UART Used
-1 for inherited
Blocking Function
Output Default
Received Output Flag
  • 1 if one byte has been received,
  • 0 if no data has been received ; the output value is the "Output Default" value.
