TECHNICAL WIKI
DsPIC Block/Output Compare
Block Output Compare
Outline
Output Compare Dialog
  • Time Up and Period
  • Time Down and Period
  • Time Up and Time Down
Up or Down or Period = Tset*OCkmaxMaxChannelT_{set} * \frac{OCkmax}{MaxChannel}
With
for example, if the max value is set to 20ms (MaxChannel = 2010−32010^{-3}) on channel 1
110−3OC1max2010−3110^{-3}\frac{OC1max}{2010^{-3}}
Interrupt Priority
Output Channels
Channels Input Type
  • 3 : is to set both High and low pulse duration
  • 5 : is to set both High pulse duration and periode
  • 10 : is to set both Down pulse duration and periode
Max/Channels
Related block & Examples
Related block:
Examples:
