DsPIC Block/Output Compare HW
Block Output Compare
Outline
Output Compare Dialog
- Time Up and Period
- Time Down and Period
- Time Set and Reset
Up or Down or Periode =
With
for example, if the max value is set to 20ms (MaxChannel = ) on channel 1
Output Channels
Channels Input Type
Periode as block input
Period Max
Related block & Examples
Related block:
Examples:
- Hyper_Sampling
- forum : </forum/topic/242/>
- forum : </forum/topic/312/>
