DsPIC Block/Master
Master Block
Master Block Dialog for the 30f3012 chip, General Tab
Master Block Dialog for the 30f3012 chip, Quartz Tab
Step Based on
PIC
59 Supported devices :
Time Step reference is the ADC peripheral. ADC conversion are slowed down so as to meet the time step requirement set in Simulink. On this example, Three channels are converted ; Two sample are read at each step (i.e. the three ADC blocks output are vectors of 2 elements each).
With FreqQuartz the frequency of the source (Quartz or internal oscillator, External Clock ...) and with PLL factor set to 1 when PLL multiplication is not used.
: From the entered Desired Instruction Cycle Frequency, the toolbox compute the best PLL multiplication which provides the Instruction Cycle Frequency the closest to the Desired one.
Config Timer
Busy Flag Port
Overload Flag Port
config Oscillator mode
config Born Out Reset
config Power Time
config MCLR
