TECHNICAL WIKI
DsPIC Block/Interface Tx-Matlab
Interface PIC-Matlab
Real-Time Consideration
  • On the simulink model, make sure to not overload the UART. Check that you are sending less data than max allowed by the UART bauds. To count the number of bytes used, when using the Tx-Labview-Matlab block, add one byte for each data sent. For example sending one uint8 data takes 2 bytes, uint16 data takes 3 bytes and uint32 data takes 5 bytes.
  • Reconstruct a vector timing corresponding to the simulink's UART timing.
Forum related question
real time : </forum/topic/207/#p787>
