TECHNICAL WIKI
DsPIC Block/External Interrupt PWM
Block External Interrupt PWM
External Interrupt Dialog
Port
ext Interrupt Priority
Capture PWM
Max capture Time
Safety Margin in %
Change Detected on
Block Ordering Input/Output
