TECHNICAL WIKI
DsPIC Block/Digital Input
Block Digital Input
Block Digital Input
The Digtal Input block reads the logical value of the selected microcontroller pin.
Digital Input Dialog
Port
  • Port used
Pin
  • Pin used, start at 0 and is defined in vector form allowing several Pin to be read at the same time.
  • -1 is inherited
