TECHNICAL WIKI
DsPIC Block/CAN Configuration
Block CAN Configuration
When using either a CAN Receive block or a CAN Transmit block, this block configure the mode and the CAN BUS parameters.
CAN Configuration Dialog
Num CAN
Ref to the CAN peripheral being configured (some PICs have two CAN buses)
Mode
  • Normal : the one you will use in most cases.
  • Loop back : Allows testing of the CAN peripheral and the CAN blockset. In this mode, no external connection or driver is necessary to make the CAN peripheral work. Messages transmitted are routed directly into the receive logic.
  • Listen only : The CAN peripheral receives messages on the bus without transmitting (not even acknowledge bits).
This mode will use only the Receive pin of the CAN peripheral The Transmit pin can be used for another purpose.
  • Disable : shut down the CAN peripheral.
These parameters configure the Timing of the CAN bus. Refer to the CAN documentation for more information.
  • TRefCAN
  • Baud Rate Prescaler - 1
  • Propagation Time Segment quanta
  • Phase Buffer Segment 1
  • Times to Sample
  • Phase Buffer Segment 2
  • Synchronisation max jump (Tq)
The time quanta Tq and the bus frequency Fcan are updated in the Info display each time one of these parameters is modified.
Information: the time quantum length Tq and the baud rate of the CAN, given the input oscillator timing TRefCan
Warning
I suspect this affects many, if not all, PIC microcontrollers with CAN (rather than ECAN) modules.
see forum related remark: </forum/topic/387/>
