Template:Documentation/core/doc
< Template:Documentation | core
Revision as of 23:05, 30 August 2010 by LubinKerhuel (talk | contribs) (Created page with "{{Documentation subpage}} <!-- PLEASE ADD CATEGORIES AND INTERWIKIS AT THE BOTTOM OF THIS PAGE --> This is the {{tl|documentation/core}} sub-template. Do not use this template ...")
This is a documentation subpage for Template:Documentation/core (see that page for the template itself). It contains usage information, categories, interlanguage links and other content that is not part of the original template page. |
This is the {{documentation/core}} sub-template.
Do not use this template directly, use {{documentation}} instead.
{{documentation}} calls {{documentation/core2}} which in turn calls this template. This template holds most of the code for {{documentation}}, while {{documentation}} and {{documentation/core2}} do parameter preprocessing. Thus simplifying the code.
Technical details
This sub-template currently expects these parameters:
{{documentation/core | heading = {{{heading|¬}}} <!--Note that the "¬" is necessary so we can detect the difference between empty and undefined--> | heading-style = {{{heading-style|}}} | content = {{{content|}}} <!--Text instead of a /doc page--> | link box = {{{link box|}}} <!--So "link box=off" works--> | docpage = <!--Full pagename of the doc page--> | doc exist = <!--"yes" if the doc page exists, empty string if not--> | docname fed = <!--"yes" if a docname was manually fed--> | sandbox = <!--Full pagename of the /sandbox--> | testcases = <!--Full pagename of the /testcases--> | template page = <!--Full pagename where the {{documentation}} template is placed, but without ending /sandbox or /testcases. Note: Unfortunately might not be the "correct" namespace if the template is in subject space and the {{documentation}} template is in talk space or the other way around.--> }}
For more documentation see {{documentation}}.
