SPI communication between two dsPIC
Description
The PWM wire is removed.
Data are sent from A ==> B but no data are sent from B ==> A. Thus only one data wire is required here. The SS pin (that is the SPI chip select when configured as slave) is not workable on the dsPIC 30f4012. The SPI slave peripheral is always enabled. Thus, the CS wire is not required also. Thus only two wires are necessary : The Clk for the Clock. The SDO (output) pin of A is connected to the SDI (input) of B. .
Simulink models
Model A: Emission
Execution time is 2.25% of a time step
