Picooz
- One Picooz
- One Atlas
They are built by Silverlit
Picooz
Weight
- EPP : 1.57g
- accumulator : 1.87g
- Electronic board : 0.85g
- tail propeller : 0.08g
- tail motor : 0.63g
- tail motor housing : 0.17g
- tail main bar : 0.37g
- tail paper : 0.02g
main rotor force
Tail rotor force
Accumulator
Onboard electronic
Atlas
Sky Cruiser (NIKKO)
- Total weight: 23.97g
- Red external cokpit weight: 2.76g
Accu: Full River 140mAh This helicopter does not have enough power to lift-up its weight except for the 20 first seconds. Then, the helicopter flight close to the ground thanks to the ground effect. Remote control is not an Infra Red one, but a real radio link (27Mhz). Removing the red cockpit allows normal flight, except that it goes slightly backward. The thin wire on the picture is the helicopter antenna (and not a broken wire that should be soldered to the tail rotor as it has been reported on some forum).
