Description
Scope picture of a PWM Signal generated by the microcontroller (A), here a large duty cycle code for a large value
Scope picture of a PWM Signal generated by the microcontroller (A), here a small duty cycle code a small value
PWM Circuit
Bootloader
Simulink models
Common parts
Master block
Bootloader RESET
Model (A): Emission
Sine wave generation
Measuring Time Step
PWM Generation
Model B: Reception
