Revision as of 02:30, 14 February 2011 by LubinKerhuel (talk | contribs)
Description
Scope picture of a PWM Signal with a large duty cycle
Scope picture of a PWM Signal with a small duty cycle
PWM Circuit
Bootloader
Simulink models
Common parts
Master block
Bootloader RESET
Model (A): Emission
Sine wave generation
Measuring Time Step
PWM Generation
Model B: Reception
