DsPIC Block/Output Compare
Outline
- Time Up and Period
- Time Down and Period
- Time Up and Time Down
With
Interrupt Priority
Output Channels
Channels Input Type
Max/Channels
Related block & Examples
Related block:
Examples:
- Hyper_Sampling
