DsPIC Block/CAN Transmit
Block CAN Transmit
Write data to a CAN bus
CAN Transmit Dialog
Num CAN
Tx Priority
Each message is assigned to a priority. When the two buffer of the CAN Peripheral contains two message, the message with the highest priority is being sent first. Four priority level exist :
  • Highest
  • High
  • Low
  • Lowest
Identifier Length
  • Standard 11 bits identifier
  • Extended 29 bits identifier
Identifier is a block input
Remote Request
Data Length Code Bits
Error flags
  • Tx Buffer Full
  • Tx CAN Bus Off
  • Tx CAN Bus Passive
  • Tx CAN Warning
Information
