CAN communication between two dsPIC
Description
This example shows two dsPIC 30f4012 exchanging data through a bus CAN. The dsPIC embedded program is generated through Simulink and Realtime-Workshop Embedded Coder and the dsPIC blockset. The CAN bus is symmetrical consequently there is no master and no slave. Every 2ms, each dsPIC place data on the bus to be read by the other dsPIC. The internal dsPIC CAN peripheral arbitrate bus access to avoid conflict (only one peripheral can write to the bus at one time). Both dsPIC copy received data to its UART and also add few other data like CAN bus state etc… The dsPIC UART is connected to the PC and the Matlab graphical interface [[Block/Interface_Tx-Matlab|rs232gui}} allows to plot theses data in real time.
Characteristics of a CAN bus
CAN acronym stands for Controller Area Network. It is a numerical bus coding its two states (one dominant and one recessive) using differential voltage between its two wires named respectively CANH and CANL.
CAN bus is a multi-slave bus where any connected dispositive can send a message. Frames are composed of an id which is set by user, and 1 to 8 data bytes. Device waiting for a specific data will filter out incoming frames based on their id. Thus both emitter and receiver exchanging data must have in common the frame id that will be used.
The CAN Configuration block configure CAN peripheral like bus frequency, time quanta, … This block is required as soon as one CAN peripheral is used.
The block CAN Transmit define frame id, data length (1 to 8 bytes) …
The block CAN Receive filter out id, set max length of the incoming frame…
The PWM wire is removed.
Simulink models
Let’s considere only the specific parts related to the CAN bus of these two models.
Model A: Emission
The model A creates an internal sine wave signal of type int16 with amplitude 5000 and frequency 4 Hz. Optimized method for sine wave generation was described in the PWM example.
