error compilation
ELMAY
error compilation
Post by ELMAY » Thu Apr 14, 2011 3:26 pm
### Starting Microchip Embedded Target build procedure for model: Demo30f
### Generating code into build directory: D:\Documents and Settings\ELMAY\Bureau\Demo30f_dspic_ert\src
Warning: The file containing block diagram 'dsPICConfigLib' is shadowed by a file of the same name higher on the MATLAB
path. This can cause unexpected behavior.  For more information see "Avoiding Problems with Shadowed Files" in the
Simulink documentation
Warning: The file containing block diagram 'dsPICRunTimeLib' is shadowed by a file of the same name higher on the MATLAB
Warning: The file containing block diagram 'forumkerhueladc_filter_OC' is shadowed by a file of the same name higher on
the MATLAB path. This can cause unexpected behavior.  For more information see "Avoiding Problems with Shadowed Files" in
the Simulink documentation
Warning: Cannot attach component to a locked object
Warning: Changing property 'LifeSpan' is not allowed.
### Invoking Target Language Compiler on Demo30f.rtw
	tlc
	-r
	D:\Documents and Settings\ELMAY\Bureau\Demo30f_dspic_ert\src\Demo30f.rtw
	D:\Documents and Settings\ELMAY\Bureau\dsPIC_Matlab\dspic\dsPIC_stf.tlc
	-OD:\Documents and Settings\ELMAY\Bureau\Demo30f_dspic_ert\src
	-ID:\Documents and Settings\ELMAY\Bureau\dsPIC_Matlab\dspic
	-ID:\Documents and Settings\ELMAY\Bureau\dsPIC_Matlab\dspicblks
	-ID:\Documents and Settings\ELMAY\Bureau\Demo30f_dspic_ert\src\tlc
	-ID:\Program Files\MATLAB\R2009b\rtw\c\tlc\mw
	-ID:\Program Files\MATLAB\R2009b\rtw\c\tlc\lib
	-ID:\Program Files\MATLAB\R2009b\rtw\c\tlc\blocks
	-ID:\Program Files\MATLAB\R2009b\rtw\c\tlc\fixpt
	-ID:\Program Files\MATLAB\R2009b\stateflow\c\tlc
	-aEnforceIntegerDowncast=1
	-aFoldNonRolledExpr=1
	-aInlineInvariantSignals=0
	-aInlineParameters=0
	-aLocalBlockOutputs=1
	-aRollThreshold=5
	-aInitFltsAndDblsToZero=1
	-aForceBlockIOInitOptimize=0
	-aGenerateReport=0
	-aGenCodeOnly=0
	-aRTWVerbose=1
	-aIncludeHyperlinkInReport=0
	-aLaunchReport=0
	-aGenerateTraceInfo=0
	-aForceParamTrailComments=0
	-aGenerateComments=1
	-aIncHierarchyInIds=0
	-aMaxRTWIdLen=31
	-aShowEliminatedStatements=0
	-aIncDataTypeInIds=0
	-aInsertBlockDesc=0
	-aIgnoreTestpoints=0
	-aSimulinkBlockComments=1
	-aInlinedPrmAccess="Literals"
	-aIsPILTarget=0
	-aIncludeMdlTerminateFcn=0
	-aCombineOutputUpdateFcns=1
	-aSuppressErrorStatus=0
	-aERTCustomFileBanners=1
	-aLogVarNameModifier="rt_"
	-aGenerateFullHeader=1
	-aGenerateSampleERTMain=0
	-aMatFileLogging=0
	-aMultiInstanceERTCode=0
	-aPurelyIntegerCode=0
	-aPortableWordSizes=0
	-aGenerateErtSFunction=0
	-aGenerateASAP2=0
	-aExtMode=0
	-aExtModeStaticAlloc=0
	-aExtModeTransport=0
	-aExtModeTesting=0
	-aTargetOS="BareBoardExample"
	-aRateGroupingCode=1
	-aRTWCAPISignals=0
	-aRTWCAPIParams=0
	-aRootIOStructures=0
	-aPICTYPE="30F4011"
	-aOGCC="-O3 -g -fschedule-insns -fschedule-insns2"
	-aLDFS="-t --report-mem -Map ../untitled.map --heap 0  -cref"
	-aMCPATH="D:\PROGRA~1\MICROC~1\mplabc30\v3.25"
	-aLINKERSCRIPT="D:\Program Files\Microchip\mplabc30\v3.25\support\dsPIC30F\gld\p30F4011.gld"
	-aPICLIB="D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\dsPIC30F\libp30F4011-coff.a D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libpic30-coff.a D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libm-coff.a D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libc-coff.a D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libq-coff.a D:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libq-dsp-coff.a"
	-aPICINCL=" -ID:\PROGRA~1\MICROC~1\mplabc30\v3.25\include -ID:\PROGRA~1\MICROC~1\mplabc30\v3.25\support\dsPIC30F\h"
	-aProtectedModelReferenceTarget=0
	-p10000
### Writing header file Demo30f_types.h
### Writing header file Demo30f.h
### Writing source file Demo30f.c
### Writing header file Demo30f_private.h
### Writing source file main.c
### Writing source file Interrupts.c
### Processing Template Makefile: D:\Documents and Settings\ELMAY\Bureau\dsPIC_Matlab\dspic\dsPIC_gcc.tmf
### Creating Demo30f.mk from D:\Documents and Settings\ELMAY\Bureau\dsPIC_Matlab\dspic\dsPIC_gcc.tmf
### Building Demo30f: "%MATLAB%\bin\win32\gmake" -f Demo30f.mk  GENERATE_REPORT=0 MULTI_INSTANCE_CODE=0 PORTABLE_WORDSIZES=0 GENERATE_ASAP2=0 TMW_EXTMODE_TESTING=0
Le chemin d'accŠs sp‚cifi‚ est introuvable.
### Real-Time Workshop build procedure for model: 'Demo30f' aborted due to an error.
Re: error compilation
Post by LubinKerhuel » Thu Apr 14, 2011 3:58 pm
Try to add the yellow block that configure automatically the model (it may resolve incorrect path).
It seems you may have to clean up your matlab path.
Do you have multiple blockset installed ? (like microchip official one, mine or others ?)
Please install latest blockset version. I am not sure you are using the last one.
does the model in the example directory compile ?
Zemog Zurc
Post by Zemog Zurc » Wed Jul 23, 2014 5:09 pm
Hello Lubin
I´ve experienced the same problem but in different way because I try to compile a blinking led project using the dsPIC30F4011 but when I compile it an error appears.
My error is:
Blinking_led_main.c:32: error: 'BORV_20' undeclared here (not in a function)
gmake: *** [Blinking_led_main.o] Error 255
I thing the problem could be the compiler. Mine is C30 v3.31.
If you have some suggest I will thank you so much.
The optimist says, “The glass is half full”.
The pessimist says, “The glass is half empty”.
The engineer says, “The glass is twice as big as it needs to be”.
Post by LubinKerhuel » Thu Jul 24, 2014 2:26 pm
Hi Zemog,
I would recommend to use the new blockset we are developping now at Microchip. You might find a free demo version at http://www.microchip.com/SimulinkBlocks
The current version is the V3.30 but a new version with many fixed issues will be release soon.
You might also use the microchip forum for questions about this new Microchip Blockset: http://www.microchip.com/forums/f192.aspx
Do not hesitate to post any issues you might encounter or any new features you would like to have.
