How to change directory?
I'm new user, How to change directory C:\Program File\Microchip\MPLAB C30 in C:\Programmi\Microchip\MPLAB C30 ?
Michele
Michele
Re: How to change directory?
Hi Michele,
a similar problem with its solution are described here : viewtopic.php?f=5&t=73#p152
Adapt and try the solution proposed.
adaptation would be ==> rtw_alt_pathname('C:\Programmi\Microchip\MPLAB C30')
If you still have the problem, please let us know.
from viewtopic.php?f=5&t=73#p152 :
Simulation ==> Configuration Parameters ==> Real-Time Workshop ==> DsPIC options
(part 2 of the solution)
did you correct the parameters in the simulink model :LubinKerhuel wrote:You can check by typing at the matlab prompt the command:
rtw_alt_pathname('C:\Program Files\Microchip\MPLAB C30')
If you do not get C:\PROGRA~1\MICROC~1\MPLABC~1, you will have to change the short path in Simulink :
Something is wrong.
In the Real Time Workshop , you have
- Comment
- Symbols
- Custom Code
- Debug
You should have
- Comment
- Symbols
- Custom Code
- Debug
- DsPIC options
Could you try to select another target than dsPIC.tlc (ert.tlc or any other), click apply, then, choose again dsPIC.tlc, click apply and look at the command windows for any error? Could you report the error you get here?
Which matlab version are you using?
I will try to find out what's happening as soon as I can...
- Comment
- Symbols
- Custom Code
- Debug
You should have
- Comment
- Symbols
- Custom Code
- Debug
- DsPIC options
The file dspic.tlc is correct but when load there isn't "DsPIC options"
and I've simulink version :
- MWSnap.gif (46.79 KiB) Viewed 37851 times
Error:
Warning: Error using ==> getSTFInfo at 76
The following error occurred processing the System Target File '':
Error using ==> getPathName
The path 'C:\Program Files\Microchip\MPLAB C30' does not exist
> In C:\Programmi\MATLAB\R2007b\toolbox\rtw\rtw\stf2target.p>stf2target at 61
In open at 148
In uiopen at 196
Warning: Error evaluating 'LoadFcn' callback of Master block (mask) 'Master'. Error using ==> dsPIC_ConfigRTWOption
at 34
The *System Target File must be defined to dsPIC Real Time workshop (Simulation ==> Configuration Parameters ==>
Real Time workshop.
In open at 148
In uiopen at 196
Warning: In instantiating linked block 'Servo_ADC/ADC Input' : Invalid setting in dsPIC : ADC10 block (mask) 'ADC
Input' for parameter 'OutFormatBitspopup'.
> In C:\MyToolBox\blocks\dsPIC_PWM_OC_callback.p>dsPIC_PWM_OC_callback at 94
In open at 148
In uiopen at 196
at 34
Real Time workshop.
> In C:\MyToolBox\blocks\dsPIC_ADC_callback_InitMask.p>dsPIC_ADC_callback_InitMask at 9
In open at 148
In uiopen at 196
In C:\Programmi\MATLAB\R2007b\toolbox\rtw\rtw\@RTW\@TargetBrowser\uploadTarget.p>uploadTarget at 20
In C:\Programmi\MATLAB\R2007b\toolbox\rtw\rtw\private\targetBrowserCloseCB.p>targetBrowserCloseCB at 9
In C:\Programmi\MATLAB\R2007b\toolbox\rtw\rtw\rtwprivate.p>rtwprivate at 12
In simulink\private\configDlgAction at 93
In slprivate at 12
In slprivate at 12
In open at 148
In uiopen at 196
at 34
Real Time workshop.
In open at 148
In uiopen at 196
In open at 148
In uiopen at 196
at 34
Real Time workshop.
In open at 148
In uiopen at 196
In slprivate at 12
In slprivate at 12
This is a bug !
I'll correct that. Thanks for screenshoot and bug description...
It's corrected, C30 can now be installed in the directory : C:\Programmi\Microchip\MPLAB C30 or in the directory : C:\Program Files\Microchip\MPLAB C30
Could you give a try to the new version ? (download it on from website)
wow now work!!! Thank you
dsPIC_ConfigRTWOption at 34
Real Time workshop.
pic30-coff-bin2hex ..\../Servo_ADC.coff
"*** Created "executable": ..\../Servo_ADC.hex"
### Successful completion of Real-Time Workshop build procedure for model: Servo_ADC
Real Time workshop.
In open at 148
In uiopen at 196
In open at 148
In uiopen at 196
Number of I/O PINs used : 2
### Starting Real-Time Workshop build procedure for model: Servo_ADC
### Generating code into build directory: C:\MyToolBox\examples\Servo_ADC_dspic\sources
Warning: Source 'Servo_ADC/ADC Input' specifies that its sample time (-1) is back-inherited. You should explicitly
specify the sample time of sources. You can disable this diagnostic by setting the 'Source block specifies -1
sample time' diagnostic to 'none' in the Sample Time group on the Diagnostics pane of the Configuration Parameters
dialog box.
### Invoking Target Language Compiler on Servo_ADC.rtw
tlc
-r
C:\MyToolBox\examples\Servo_ADC_dspic\sources\Servo_ADC.rtw
C:\MyToolBox\dspic\dspic.tlc
-OC:\MyToolBox\examples\Servo_ADC_dspic\sources
-IC:\MyToolBox\dspic
-IC:\MyToolBox\blocks
-IC:\MyToolBox\examples\Servo_ADC_dspic\sources\tlc
-IC:\Programmi\MATLAB\R2007b\rtw\c\tlc\mw
-IC:\Programmi\MATLAB\R2007b\rtw\c\tlc\lib
-IC:\Programmi\MATLAB\R2007b\rtw\c\tlc\blocks
-IC:\Programmi\MATLAB\R2007b\rtw\c\tlc\fixpt
-IC:\Programmi\MATLAB\R2007b\stateflow\c\tlc
-aEnforceIntegerDowncast=1
-aFoldNonRolledExpr=1
-aInlineInvariantSignals=0
-aInlineParameters=0
-aLocalBlockOutputs=1
-aRollThreshold=5
-aInitFltsAndDblsToZero=1
-aGenerateReport=0
-aGenCodeOnly=0
-aRTWVerbose=1
-aIncludeHyperlinkInReport=0
-aLaunchReport=0
-aGenerateTraceInfo=0
-aForceParamTrailComments=0
-aGenerateComments=1
-aIncHierarchyInIds=0
-aMaxRTWIdLen=31
-aShowEliminatedStatements=0
-aIncDataTypeInIds=0
-aInsertBlockDesc=0
-aSimulinkBlockComments=1
-aInlinedPrmAccess="Literals"
-aIsPILTarget=0
-aIncludeMdlTerminateFcn=0
-aCombineOutputUpdateFcns=1
-aSuppressErrorStatus=1
-aERTCustomFileBanners=1
-aLogVarNameModifier="rt_"
-aGenerateFullHeader=1
-aGenerateSampleERTMain=0
-aMatFileLogging=0
-aMultiInstanceERTCode=0
-aPurelyIntegerCode=0
-aPortableWordSizes=0
-aGenerateErtSFunction=0
-aGenerateASAP2=0
-aExtMode=0
-aExtModeStaticAlloc=0
-aExtModeTransport=0
-aExtModeTesting=0
-aTargetOS="BareBoardExample"
-aRateGroupingCode=1
-aRTWCAPISignals=0
-aRTWCAPIParams=0
-aRootIOStructures=0
-aLDFLAGS="-t --report-mem -Map ../untitled.map --heap 0 -cref"
-aLDPICTYPE="-T C:\PROGRA~1\MICROC~1\MPLABC~2\support\gld\p30f3012.gld"
-aLDLIBPIC="C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libpic30-coff.a C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libp30F3012-coff.a C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libc-coff.a C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a"
-aPIC_REF="30f3012"
-p10000
### Writing header file Servo_ADC_types.h
### Writing header file Servo_ADC.h
### Writing source file Servo_ADC.c
### Writing header file Servo_ADC_private.h
### Writing source file Servo_ADC_data.c
### Writing source file Servo_ADC_main.c
Companie =
Embedded Coder for dsPIC V0.96b(13-Feb-2008) for Matlab R2007b.
informations available at http://www.kerhuel.eu
### Processing Template Makefile: C:\MyToolBox\dspic\dspic_pic30_gcc.tmf
### <C:\PROGRA~1\MATLAB\R2007b\bin\win32\gmake>
### in default batch file
### Creating Servo_ADC.mk from C:\MyToolBox\dspic\dspic_pic30_gcc.tmf
### Building Servo_ADC: .\Servo_ADC.bat
C:\MyToolBox\examples\Servo_ADC_dspic\sources>set MATLAB=C:\Programmi\MATLAB\R2007b
C:\MyToolBox\examples\Servo_ADC_dspic\sources>C:\PROGRA~1\MATLAB\R2007b\bin\win32\gmake -f Servo_ADC.mk GENERATE_REPORT=0 MULTI_INSTANCE_CODE=0 PORTABLE_WORDSIZES=0 GENERATE_ASAP2=0 TMW_EXTMODE_TESTING=0
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include Servo_ADC_data.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include Servo_ADC_main.c
Servo_ADC_main.c: In function 'main':
Servo_ADC_main.c:58: warning: 'return' with a value, in function returning void
Servo_ADC_main.c:48: warning: return type of 'main' is not 'int'
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include dsPIC_OutputCompare_Interrupt.c
dsPIC_OutputCompare_Interrupt.c: In function '_OC1Interrupt':
dsPIC_OutputCompare_Interrupt.c:7: warning: PSV model not specified for '_OC1Interrupt';
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include Servo_ADC.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_backsubcc_dbl.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_backsubcc_sgl.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_backsubrc_dbl.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_backsubrc_sgl.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_backsubrr_dbl.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_backsubrr_sgl.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_enab.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_forwardsubcc_dbl.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_forwardsubcc_sgl.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_forwardsubcr_dbl.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_forwardsubcr_sgl.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_forwardsubrc_dbl.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_forwardsubrc_sgl.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_forwardsubrr_dbl.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_forwardsubrr_sgl.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_look.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_look1d.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_look1d32.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_look2d32_general.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_look2d32_normal.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_look2d_general.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_look2d_normal.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_look32.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_lu_cplx.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_lu_cplx_sgl.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_lu_real.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_lu_real_sgl.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_matdivcc_dbl.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_matdivcc_sgl.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_matdivcr_dbl.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_matdivcr_sgl.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_matdivrc_dbl.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_matdivrc_sgl.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_matdivrr_dbl.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_matdivrr_sgl.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_matmultandinccc_dbl.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_matmultandinccc_sgl.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_matmultandinccr_dbl.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_matmultandinccr_sgl.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_matmultandincrc_dbl.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_matmultandincrc_sgl.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_matmultandincrr_dbl.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_matmultandincrr_sgl.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_matmultcc_dbl.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_matmultcc_sgl.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_matmultcr_dbl.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_matmultcr_sgl.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_matmultrc_dbl.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_matmultrc_sgl.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_matmultrr_dbl.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_matmultrr_sgl.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_sat_div_int16.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_sat_div_int32.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_sat_div_int8.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_sat_div_uint16.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_sat_div_uint32.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_sat_div_uint8.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_sat_prod_int16.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_sat_prod_int32.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_sat_prod_int8.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_sat_prod_uint16.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_sat_prod_uint32.c
pic30-gcc -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_sat_prod_uint8.c
"### Creating rtwlib.a "
pic30-ar -r rtwlib.a rt_backsubcc_dbl.o rt_backsubcc_sgl.o rt_backsubrc_dbl.o rt_backsubrc_sgl.o rt_backsubrr_dbl.o rt_backsubrr_sgl.o rt_enab.o rt_forwardsubcc_dbl.o rt_forwardsubcc_sgl.o rt_forwardsubcr_dbl.o rt_forwardsubcr_sgl.o rt_forwardsubrc_dbl.o rt_forwardsubrc_sgl.o rt_forwardsubrr_dbl.o rt_forwardsubrr_sgl.o rt_look.o rt_look1d.o rt_look1d32.o rt_look2d32_general.o rt_look2d32_normal.o rt_look2d_general.o rt_look2d_normal.o rt_look32.o rt_lu_cplx.o rt_lu_cplx_sgl.o rt_lu_real.o rt_lu_real_sgl.o rt_matdivcc_dbl.o rt_matdivcc_sgl.o rt_matdivcr_dbl.o rt_matdivcr_sgl.o rt_matdivrc_dbl.o rt_matdivrc_sgl.o rt_matdivrr_dbl.o rt_matdivrr_sgl.o rt_matmultandinccc_dbl.o rt_matmultandinccc_sgl.o rt_matmultandinccr_dbl.o rt_matmultandinccr_sgl.o rt_matmultandincrc_dbl.o rt_matmultandincrc_sgl.o rt_matmultandincrr_dbl.o rt_matmultandincrr_sgl.o rt_matmultcc_dbl.o rt_matmultcc_sgl.o rt_matmultcr_dbl.o rt_matmultcr_sgl.o rt_matmultrc_dbl.o rt_matmultrc_sgl.o rt_matmultrr_dbl.o rt_matmultrr_sgl.o rt_sat_div_int16.o rt_sat_div_int32.o rt_sat_div_int8.o rt_sat_div_uint16.o rt_sat_div_uint32.o rt_sat_div_uint8.o rt_sat_prod_int16.o rt_sat_prod_int32.o rt_sat_prod_int8.o rt_sat_prod_uint16.o rt_sat_prod_uint32.o rt_sat_prod_uint8.o
"### rtwlib.a Created"
pic30-ld -t --report-mem -Map ../untitled.map --heap 0 -cref -T C:\PROGRA~1\MICROC~1\MPLABC~2\support\gld\p30f2010.gld -o ..\../Servo_ADC.coff Servo_ADC_data.o Servo_ADC_main.o dsPIC_OutputCompare_Interrupt.o Servo_ADC.o rtwlib.a C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libpic30-coff.a C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libp30F2010-coff.a C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libc-coff.a C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a
C:\Programmi\Microchip\MPLAB C30\bin\pic30-coff-ld.exe: mode pic30_coff
Servo_ADC_data.o
Servo_ADC_main.o
Servo_ADC.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libpic30-coff.a)crt1.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libpic30-coff.a)crt0.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libp30F2010-coff.a)ConfigIntTimer1.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libp30F2010-coff.a)ConfigIntTimer2.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libp30F2010-coff.a)OpenTimer2.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libp30F2010-coff.a)OpenOC1.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libp30F2010-coff.a)ConfigIntOC1.o
Program Memory Usage
section address length (PC units) length (bytes) (dec)
.reset 0 0x4 0x6 (6)
.ivt 0x4 0x7c 0xba (186)
.aivt 0x84 0x7c 0xba (186)
.text 0x100 0x1d4 0x2be (702)
.dinit 0x2d4 0x1e 0x2d (45)
.isr 0x2f2 0x2 0x3 (3)
__FOSC 0xf80000 0x2 0x3 (3)
__FWDT 0xf80002 0x2 0x3 (3)
__FBORPOR 0xf80004 0x2 0x3 (3)
__FGS 0xf8000a 0x2 0x3 (3)
Total program memory used (bytes): 0x474 (1140) 9%
Data Memory Usage
section address alignment gaps total length (dec)
.ndata 0x800 0 0x6 (6)
.nbss 0x806 0 0x4 (4)
.nbss 0x80a 0 0x4 (4)
.nbss 0x80e 0 0x2 (2)
Total data memory used (bytes): 0x10 (16) 3%
Dynamic Memory Usage
region address maximum length (dec)
heap 0 0 (0)
stack 0x810 0x1f0 (496)
Maximum dynamic memory (bytes): 0x1f0 (496)
"*** Embedded Target for dsPIC written by Lubin KERHUEL - http://www.kerhuel.eu"
"*** Licence Accorded to Demonstration Version "
"*** Version 0.96b 13-Feb-2008 "
"*** For Matlab 7.5 R2007b "
"*** Created "executable": ..\../Servo_ADC.coff"
There is a problem, when compiling example "Servo_ADC.mdl" work very well , but when compiling another example give me error:
I can't see the error on the image (it is cut) however, I guess that it says that the linker script ***.gld is missing.
This script is provided with the C30 compiler. Could you check that you installed it and that it is present in the correct directory?
Ok resolve it , the problem is :
Now all the examples are compiled perfectly.
But I did a test in dsPIC33_f_Explorer16 I changed into "dspic master processor in the box PIC24fj128GA10, make an error "Error ==> genMakefileAndBuild at 1070"
change processor and the error is:
informations available at www.kerhuel.eu
### Creating dsPIC_33f_Explorer16.mk from C:\MyToolBox\dspic\dspic_pic30_gcc.tmf
### Building dsPIC_33f_Explorer16: .\dsPIC_33f_Explorer16.bat
C:\MyToolBox\examples\dsPIC_33f_Explorer16_dspic\sources>set MATLAB=C:\Programmi\MATLAB\R2007b
C:\MyToolBox\examples\dsPIC_33f_Explorer16_dspic\sources>C:\PROGRA~1\MATLAB\R2007b\bin\win32\gmake -f dsPIC_33f_Explorer16.mk GENERATE_REPORT=1 MULTI_INSTANCE_CODE=0 PORTABLE_WORDSIZES=0 GENERATE_ASAP2=0 TMW_EXTMODE_TESTING=0
pic30-gcc -c -mcpu=p24FJ128GA010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\dsPIC_33f_Explorer16_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include dsPIC_33f_Explorer16_main.c
pic30-coff-cc1.exe: error: Invalid -mcpu option. CPU p24FJ128GA010 not recognized.
Warning: In instantiating linked block 'dsPIC_33f_Explorer16/Master' : Invalid setting in Master block (mask)
'Master' for parameter 'MCLR'.
In open at 148
In uiopen at 196
Number of I/O PINs used : 6
### Starting Real-Time Workshop build procedure for model: dsPIC_33f_Explorer16
### Generating code into build directory: C:\MyToolBox\examples\dsPIC_33f_Explorer16_dspic\sources
Warning: Source 'dsPIC_33f_Explorer16/Digital Input' specifies that its sample time (-1) is back-inherited. You
should explicitly specify the sample time of sources. You can disable this diagnostic by setting the 'Source block
specifies -1 sample time' diagnostic to 'none' in the Sample Time group on the Diagnostics pane of the
Configuration Parameters dialog box.
### Invoking Target Language Compiler on dsPIC_33f_Explorer16.rtw
tlc
-r
C:\MyToolBox\examples\dsPIC_33f_Explorer16_dspic\sources\dsPIC_33f_Explorer16.rtw
-OC:\MyToolBox\examples\dsPIC_33f_Explorer16_dspic\sources
-IC:\MyToolBox\examples\dsPIC_33f_Explorer16_dspic\sources\tlc
-aEnforceIntegerDowncast=0
-aInlineInvariantSignals=1
-aInlineParameters=1
-aRollThreshold=5
-aZeroInternalMemoryAtStartup=0
-aZeroExternalMemoryAtStartup=0
-aInitFltsAndDblsToZero=0
-aGenerateReport=1
-aGenCodeOnly=0
-aRTWVerbose=1
-aIncludeHyperlinkInReport=1
-aLaunchReport=1
-aMaxRTWIdLen=31
-aInsertBlockDesc=0
-aIsPILTarget=0
-aMatFileLogging=0
-aGenerateASAP2=0
-aExtMode=0
-aExtModeTesting=0
-aRTWCAPISignals=0
-aRTWCAPIParams=0
-aOPTIM_GCC="-mcpu=24FJ128GA010 -O3 -fschedule-insns -fschedule-insns2"
-aLDPICTYPE="-T C:\PROGRA~1\MICROC~1\MPLABC~2\support\gld\p24fj128ga010.gld"
-aLDLIBPIC="C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libpic30-coff.a C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libpPIC24Fxxx-coff.a C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libc-coff.a C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a"
-aPIC_REF="24fj128ga010"
-p10000
### Writing header file dsPIC_33f_Explorer16_types.h
### Writing header file dsPIC_33f_Explorer16.h
### Writing source file dsPIC_33f_Explorer16.c
### Writing header file dsPIC_33f_Explorer16_private.h
### Writing source file dsPIC_33f_Explorer16_main.c
### Creating HTML report file dsPIC_33f_Explorer16_codegen_rpt.html
Companie =
pic30-gcc -c -mcpu=24FJ128GA010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\dsPIC_33f_Explorer16_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~2\include dsPIC_33f_Explorer16_main.c
In file included from c:/programmi/microchip/mplab c30/bin/../support/h/peripheral_24F/timer.h:34,
from dsPIC_33f_Explorer16_private.h:33,
c:/programmi/microchip/mplab c30/bin/../support/h/peripheral_24F/Generic.h:56: error: syntax error before '(' token
PS: excuse me for my screenshoot and my english
And thank you for your disponibility
There is a know bug for 24fj PIC.
I do not know why, if anybody has a suggestion.
The solution is described on the release page: http://www.kerhuel.eu/RTWdsPIC/ReleaseNotes.html
Know bug : before compiling schematic for dsPIC 24f, you must remove the line 56 of Generic.h file which is in
"C:\Program Files\Microchip\MPLAB C30\support\h\peripheral_24F"
The line :
"typedef enum _BOOL { FALSE = 0, TRUE } BOOL;" does not compile !
Sorry I had not seen, now everything works perfectly thanks
Users browsing this forum: No registered users and 101 guests
