Question about Filter
I saw two examples that implement filters, I noticed the speed with which you can implement filters in a dspic.
But I have a question:
How has been calculated Band pass filter?
Re: Question about Filter
Low pass filter with a cut off frequency at 1 Hz :
1Hz means 2*pi rad/s which is approximatively 6 rad/s.
matlab code :
You will get :
We have a 45° phase and a -3db cut off at 6 rad/s which is approximatively 1Hz.
6 should be replace by 2*pi so as to get a precise 1Hz low pass filter.
If you are note familiar with theses math, have a look on the Laplace transform.
The filter is then discretized for a sampling rate of 200Hz using the c2d function with the tustin method.
matlab code :
>> Filter_1Hz = tf([6],[1 6])
Transfer function:
6
s + 6
>> bode(Filter_1Hz)
>> You will get :
can simu kalman filter ????
I will have a look on kalman filter to estimate the gyro bias. But I could not give a date when I will do it.
You could do it anyway !
